Lexar Flash memory card - 256 MB - SD Logo
A
Anonymous Posted on Jan 24, 2013
Where do i find the serial number on a Lexar memory card?
1 Related Answer
Anonymous
  • 256 Answers
  • Posted on May 28, 2009
SOURCE: my memory card won't work in my camerakeeps telling me to format the Lexar 2GB card every time I insert it
Use the camera to format the SD card not your computer. There should be a menu option to format it.
How to access lexar memory card without loker,my memory card loker has been breaked
If it's still a usable card, I would suggest just placing it back into your camera and then connecting it via USB cord.
If that doesn't work, check if your computer has a slot for SD cards. If it does, try placing the card in one of the slots gently.
1helpful
Lexar 16g pro 133 sd card in canon ixus 750 says memory error card locked which ever way slide switch is. card is ok in computer Help
I'm a member of the PR team. Sorry to hear you are having these issues. We'd like to help.
Lexar support can be reached via email: [email protected] or by phone: 1-877-747-4031(US and Canada) or 1-208-363-5862 (Outside US and Canada).
2helpful
I just inserted a new 8GB memory card but it tells me ''OUT OF MEMORY'' I tried to format it but still gives me the same message. Why is that and what can I do about it please?
The memory card you are trying to use in the camera is not supported. This camera is an older technology that can not recognize the large 8 GB memory capacity of the card. In fact, the largest approved card your camera will recognize is 1 GB.
The list of approved memory cards was obtained from the Nikon Site directly, and pasted below for your convenience.
Nikon has tested the following cards and approved their use in the Coolpix 5700:
CompactFlash memory cards:
SanDisk SDCFB series 16 MB, 32 MB, 48 MB, 64 MB, 96 MB, and 128 MB
Lexar Media 4× USB series 8 MB, 16 MB, 32 MB, 48 MB, 64 MB, and 80 MB
Lexar Media 8× USB series 8 MB, 16 MB, 32 MB, 48 MB, 64 MB, and 80 MB
Lexar Media 10× USB series 128 MB and 160 MB
Lexar Media 40x USB WA series 256 MB*
Microtech International Digital Flash Film 1GB*
Delkin eFilm 650MB Pro*
Ritz Big Print 8x 256MB* (Edge Code 0E1B)
Microdrive cards:
DSCM-10512 512 MB
DSCM-11000 1 GB
Please rate this reply if it helped you out. Good luck!
I HAVE AN OLYMPUS MASTER (FE-190 )AND I HAVE LOST SERIAL NUMBER
I looked up the FE-190 and it says it uses XD Memory Cards not discs. Several companys make a card reader that plug into the USB connector
on computers. 2 are Targus and Lexar. You could probable find an XD card reader at Walmart or Radio Shack. The XD memory card will then show up
on your computer screen as a regular folder that contains JPG files, which are the pictures.
4GB Lexar Premium 60 switch is up, but the message I get says
i have the lexar 4 gb memory card with a ton of pictures which i never deleted. when i put it in a card reader it wont pop up on the screen. it wont work in my camera it will say once i turn it on (card can not be accessed reincirt/change card or format card shows up on my camera screen.) this worked a few days ago and just stopped working randomly. help me
My computer can read the Lexar 1GB SD. But Kodak wont.
I suggest formatting the card using the utility in the camera. This will delete any data that is currently on the card.
1helpful
My memory card won't work in my camerakeeps telling me to format the Lexar 2GB card every time I insert it
Lexar SDHC Card from Kodak Easy Share, disk not recoginized
Honestly, it is most likely a defective memory card or not compatible with your camera. Sorry.
Lexar card reader
yes surely sanddisk adapter will work with a lexar card reader.....
Top Lexar Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
