20 Most Recent Lexar JumpDrive Classic Portable USB Data Storage Device, 128MB. (PD0128231) Media Questions & Answers
Write protected
To remove write protection: Open Start Menu >> Run, type regedit and press Enter. This will open the registry editor. Navigate to the following path: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies Double click the key WriteProtect in the right pane and set the value to 0 In the Data Value Box, press OK Exit Registry, restart your computer and then re-connect your USB pen drive to your computer.
12/26/2013 12:32:24 AM • Lexar JumpDrive... • Answered on Dec 26, 2013
2answers
Some of my removable disk have virus that can not be removed by microsoft essential anti virus, it appears error when I select the remove option.
click start click on my computer you should see your usb drive right click then select format another way is to control panel administrive tools computer management disk management right click on your drive select format hope this helps
12/27/2012 9:25:54 AM • Lexar JumpDrive... • Answered on Dec 27, 2012
2answers
My Flash Drive is write protected how to remove
The procedure for removing the right protection is given in the website given below.
please follow the directions and you can remove it.
http://www.troublefixers.com/remove-write-protection-on-usb-pen-drive-or-memory-card-or-ipod/
Thanx
6/21/2012 8:36:49 AM • Lexar JumpDrive... • Answered on Jun 21, 2012
Move write-protect from flash drive
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select openRight click the icon of your usb drive (It should be E:/ or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control. if you need more help with this post a reply hope it helps
5/24/2012 2:31:11 PM • Lexar JumpDrive... • Answered on May 24, 2012
How do I get to the file that was downloaded off of my Game console?
you might not have saved it in a specific folderclick start type in the name of the file press enter this should locate the file folder in w7click start search in xp or you might try downloading the file again you should get the option to save as a browse option will open select the specific folder in my documents or a usb drivehope it helps
4/30/2012 9:35:41 PM • Lexar JumpDrive... • Answered on Apr 30, 2012
I have a lexar 1gb jumpdrive. found in my old
You're looking for the option to "Format" the flash drive. Plug it in to your computer, and depending on the operating system, you're going to click Start > My Computer or Compute > Then right click on the Flash Drive, it should be listed on the left hand side of the screen. Find the Format option and select it. That should delete all of the files.
8/14/2011 11:11:10 PM • Lexar JumpDrive... • Answered on Aug 14, 2011
How can I get my pictures off my Lexmar removable
Hi.. You might check to see that the external drive is actually powered up, does it need to plugged into power or is it USB connected. Try a different USB port. Go into start settings system device manager and see if the USB ports all come up ok, or if there is a yellow ? Question mark, meaning that the system isn't recognizing one or more f them (And, if that's the case, you probably need new USB drivers on the PC.. - unplug the USB device, tell windows to update the driver (or delete the bad device and reboot - windows should rebuild the USB device ))
Worst case, take the drive to a computer repair place and tell them you want to get the pictures off the drive. Unless the drive itself has died, should be able to get photos off it.
6/5/2011 5:49:23 AM • Lexar JumpDrive... • Answered on Jun 05, 2011
4 GB lexar jumpstart, new on an xp which has just
Yes, the memory chip inside it is fried. There's nothing you can do, junk it and buy a new one.
3/24/2011 9:54:27 PM • Lexar JumpDrive... • Answered on Mar 24, 2011
REMOVE WRITE PROTECTION
Please try to use the HP USB Format Utility tool to format your USB Flash Drive.I've personally used it on even the most stubborn flashdrives.Check it out!
Download it from CNET from http://download.cnet.com/HP-USB-Disk-Storage-Format-Tool/3000-2094_4-10974082.html
Thanks and welcome.
2/14/2011 5:58:38 PM • Lexar JumpDrive... • Answered on Feb 14, 2011
How do I save emails?
drag them from your pc to jumpdrive
12/19/2010 4:33:14 AM • Lexar JumpDrive... • Answered on Dec 19, 2010
Have windows xp I need a driver for a lexar 2.0 4GB
No driver needed, when plugged in it should just appear in My Computer. If it doesn't that means the memory stick is dead, junk it.
7/11/2010 1:48:01 PM • Lexar JumpDrive... • Answered on Jul 11, 2010
How do i remove write protection from my
hi
go to folowing link you will have your solution
vote me if u have your solution
7/7/2010 4:35:14 PM • Lexar JumpDrive... • Answered on Jul 07, 2010
Jumpdrive states full but is not
File system error - format it the slow way in a different system.
6/15/2010 3:55:17 PM • Lexar JumpDrive... • Answered on Jun 15, 2010
How can one folder containig so many files be
someone set all the files to be protected
you can protect any or all files with a password
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
3/31/2010 4:50:06 PM • Lexar JumpDrive... • Answered on Mar 31, 2010
My new USB drive is giving me a message that it is
it is software problem put on other system it will work
3/14/2010 2:36:31 AM • Lexar JumpDrive... • Answered on Mar 14, 2010
3answers
My usb is not being recognized when i put it in
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
3/11/2010 6:32:54 AM • Lexar JumpDrive... • Answered on Mar 11, 2010
I have a Relay 2GB U3 jumpdrive that is not being
Chances are that one or more of the components on the PCB have stopped operating properly. This is a fairly typical symptom, and usually recoverable. I would be happy to take a look at your flash drive: http://happydatarecovery.com/
Good Luck
3/7/2010 7:41:25 AM • Lexar JumpDrive... • Answered on Mar 07, 2010
Lexar JumpDrive Classic Portable USB Data Storage Device, 128MB. (PD0128231) Media Logo
Popular Tags
48 questions posted
Top Lexar Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Lexar Electronics - Others
Most Popular Question
move write protect from flash drive
  • Electronics - Others
