20 Most Recent Lexar Professional High-Speed 2GB Secure Digital Memory Card Questions & Answers
you can try this memory card recovery software called asoftech photo recovery that helped me before
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended one is this photo recovery (simply because i was using it and it worked)
http://www.asoftech.com/apr/
4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
Lexar... | Answered on Jan 15, 2014
Look on the side of the card, there is a switch. Just slide it and you will unlock your card.
Lexar... | Answered on Dec 31, 2012
If it's still a usable card, I would suggest just placing it back into your camera and then connecting it via USB cord.
If that doesn't work, check if your computer has a slot for SD cards. If it does, try placing the card in one of the slots gently.
Lexar... | Answered on Sep 20, 2012
I'm a member of the PR team. Sorry to hear you are having these issues. We'd like to help.
Lexar support can be reached via email: support@lexar.com or by phone: 1-877-747-4031(US and Canada) or 1-208-363-5862 (Outside US and Canada).
Lexar... | Answered on Sep 07, 2011
My first item to Trouble shoot i think would be your media card reader, check in your device manager to see if there are any conflicts in the driver or if a driver is even installed for it. if there is a conflict, go to your pc manufacture website go to support , drivers an download the card reader and reinstall. Also is there any data on the card? and if not has it been formated yet?
Lexar... | Answered on May 28, 2011
I wish that I could provide hope. Unfortunatly when this device is dead it is dead.
Lexar... | Answered on Mar 23, 2011
Some computers will not support a large 8GB stick. The best some will do is 2GB, If you are running a computer pre-2001, you may not be able to use the 8GB stick (I have the same problem with my desktop PC). It just is not supported!
Lexar... | Answered on Feb 09, 2011
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Lexar... | Answered on Jan 19, 2011
go to computer right click on the card & select farmat & farmat it
Lexar... | Answered on Nov 22, 2010
The switch goes fully forward for unlocked and fully back (away from the contacts) to lock it.
Lexar... | Answered on Oct 06, 2010
A flash card wears out every single time you use it. Yours has just reached its end of life - it's dead. Replace it.
Lexar... | Answered on Oct 05, 2010
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Lexar... | Answered on Aug 27, 2010
see if their might be some photos or file saved that you may have edited on the card maybe Microsoft visual studio's photo shop save to hard drive. delete with photo software and format put in camera format again. if it works with computer and not with the camera not compatible try another card
Lexar... | Answered on Jul 04, 2010
Copy your files and try to formate the memory card and then try it.
Kindly rate my help+ Thank you.
Lexar... | Answered on May 10, 2010
there should be a little swith on the side of the card. switch to the opposite and then try
Lexar... | Answered on Apr 04, 2010
i have the lexar 4 gb memory card with a ton of pictures which i never deleted. when i put it in a card reader it wont pop up on the screen. it wont work in my camera it will say once i turn it on (card can not be accessed reincirt/change card or format card shows up on my camera screen.) this worked a few days ago and just stopped working randomly. help me
Lexar... | Answered on Nov 26, 2009
There is a white switch on the side of those sticks, and make sure it is not in write protected mode. If that doesn't work, I am sorry to say that stick might of went bad. Before giving up I would take to a professional film place and have them take a look to see if they can get them off w/o formatting.
Lexar... | Answered on Nov 21, 2009
Memory cards are not made to hold pictures permanently. Like any stored data, they can be glitched and then you've lost the data. You should always copy them to the computer hard drive AND make a backup or 2. Even CDs can go bad. All my pictures are stored at least 2 but sometimes 3 places. Perhaps there is a way to retrieve the data, but I do not know how. Contact the manufacturer and see it they can help... but I'm afraid you've lost them.
Lexar... | Answered on Oct 14, 2009
Hi
there should be a little switch on the side of the memory card to lock and unlock it.
Keep us posted.
Lexar... | Answered on Oct 08, 2009
Lexar Professional High-Speed 2GB Secure Digital Memory Card Logo
36 questions posted
Top Lexar Electronics - Others Experts
Joe Negus
Joe Negus
 Mike M
Mike M
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Lexar Electronics - Others
Most Popular Question
trying recover 155 raw photo images from
  • Electronics - Others
