20 Most Recent Nikon Coolpix 5700 Digital Camera Questions & Answers
2answers
Where is nikon service center in dubai ?
If you want to fulfill your dream contact our Dubai *******. Our Independent Dubai ******* girls are able to completely your dream, they will suck your dick until you will not feel heaven. We did not provide you service on the basis of shots, we are offering the services on the basis of hours. You can take unlimited shots within hour until you will not satisfy.https://www.rainbowchicks.me/https://www.rainbowpeaches.com/https://www.rainbowhotties.com/
6/1/2020 9:56:37 PM • Nikon Coolpix... • Answered on Jun 01, 2020
Problems with the nikon coolpix 8800 vr camera
All I can tell from here is your battery is nearly dead. If you can connect it to a computer and you can see the photos on it then I would say you have a really old or bad battery or the battery is missing.
10/25/2018 1:05:59 AM • Nikon Coolpix... • Answered on Oct 25, 2018
Screen and pictures are all blurry
If it has been unused for a length of time, the internal workings are probably in need of cleaning and re-alignment.
12/26/2017 2:11:52 PM • Nikon Coolpix... • Answered on Dec 26, 2017
Cant see anything through camera
There is a button next to the viewfinder. When you press it, you go between the viewfinder and being able to see what you're shooting through the tiny video screen on the back. That should take care of it. Otherwise, it may need repair. Good luck.
5/31/2017 5:56:27 PM • Nikon Coolpix... • Answered on May 31, 2017
Pink line through the pictures
Possible your sensor needs cleaning
4/21/2017 8:01:05 AM • Nikon Coolpix... • Answered on Apr 21, 2017
The shutter keeps getting stuck and I can not take photos. How do you prevent or how to unstuck it.
Have you maybe hit the mode dial, and put it to "Timer" mode ?
1/3/2017 11:47:55 PM • Nikon Coolpix... • Answered on Jan 03, 2017
I bought a Nikon 5700 from the Pawn shop is it still covered for the recall if it needs to be fixed?
most companies , you need the original receipt, but it is worth a call, tell them you lost receipt, usually all recalls are covered no matter what.
3/29/2016 10:44:38 PM • Nikon Coolpix... • Answered on Mar 29, 2016
Lens while opening is rough
dirt in the opening mechanism,or worn/broken gear teeth caused by switching on camera while lens is restricted in opening,for example placed lens down or in carry;case.get expert attention.
1/4/2016 7:48:36 PM • Nikon Coolpix... • Answered on Jan 04, 2016
2answers
I cannot print pictures taken in nef format. Can
Hi dear, most printers can only use jpeg or bmp format .Use Irfanview to convert raw file to either one.
12/2/2015 5:45:06 AM • Nikon Coolpix... • Answered on Dec 02, 2015
What are defect pixels?
Ocassionally images from digital cameras will have "defect" pixels. These pixels may appear in the final photograph as bright white, green or red spots that are out of place when compared to the rest of the image. Sometimes people call these spots "hot" or "dead" pixels. Notice the green defect pixel near the center of this image. Usually these pixels, and other types of "digital noise" appear in the darker or underexposed parts of images; additionally, images taken at longer exposure times are much more likely to have this issue. Many Nikon cameras have a "noise reduction" or "NR" process that fixes these problem areas. When NR is activated and image exposure times drop below 1/4 of a second the NR automatically processes the images as they are saved. This Noise Reduction feature is sometimes called "Night Portrait" or "Night Landscape" Scene Modes. If these spots are seen on images photographed under normal conditions (bright light with exposure times shorter than 1/4 second) then the camera may need to be sent in to a Nikon Service Center for repair.
3/2/2015 5:29:46 PM • Nikon Coolpix... • Answered on Mar 02, 2015
Red light display with SB
The flashing red light indicates that the camera's flash is charging. Your electronic flash does not work on the low voltage supplied by the camera's battery. Instead, the battery is used to charge a capacitor(s) that are connected in a manner that raises the voltage to a level that will fire the flash. If the batteries are not adequately charged or the capacitor(s) are leaking, which will occur as they age, enough voltage will not be stored to allow the flash to fire. Make sure your batteries are fully charged. Remember, rechargeable batteries do go bad after time and must periodically be replaced. If the battery is fully charged and the red light continues to flash, the camera will need to be sent in for repair (probably replacement of the capacitor(s)). Call the Nikon Service Center at 1-800-645-6687 9AM-8PM EST, Monday to Friday, and they can arrange for you to have your camera evaluated and provide you with an estimate without cost. Your camera is rather old and it is possible that it might make more sense to replace it with a new model.
2/12/2015 1:19:22 AM • Nikon Coolpix... • Answered on Feb 12, 2015
2answers
Nikon coolpix 5700 flash isn't
I can help, I just need a few more details...
  1. Is there a blinking red dot on our screen when you try to take a picture with the flash?
  2. Is the flash poping up?
  3. Has it worked before?
1/11/2015 7:57:54 AM • Nikon Coolpix... • Answered on Jan 11, 2015
NIKON COOLPIX 36100-PTP
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa. Organize edit and share your photos
11/22/2014 7:57:28 PM • Nikon Coolpix... • Answered on Nov 22, 2014
How to get the RGM Histogram off my D80 Nikon view finder?
Press cursor-up/down to cycle through the available views of your photo.
9/23/2014 4:09:26 PM • Nikon Coolpix... • Answered on Sep 23, 2014
Won't take pictures
No by its self you have to push the button charge battery over night, put sd card in camera set your ISO, appuatue, and shutter speed the take lens cap off and shoot.
8/9/2014 8:03:56 PM • Nikon Coolpix... • Answered on Aug 09, 2014
Won't take pictures.
Put a clean sd card in, take lens cap off and turn on it should work if its not broken.
8/9/2014 8:00:11 PM • Nikon Coolpix... • Answered on Aug 09, 2014
How to format new card for a canon ds126181
Do you have the "lock" turned on, on the SD Card? Are you able to format the SD card in a computer?
5/14/2014 8:39:04 PM • Nikon Coolpix... • Answered on May 14, 2014
Monitor and viewfinder flicker
I don't have a solution, but do have the same problem. Mine is cleared by switching the camera off and back on again. Also the problem doesn't appear for long, clearing itself, on some ocassions. The problem stated when I was in a hotter climate, about 35degree celcius. I bought my camera about 3 months after release, I'd be interested to know the age of yours and if this is a common problem. Have you had your camera fixed?
5/13/2014 9:54:54 AM • Nikon Coolpix... • Answered on May 13, 2014
Nikon Coolpix 5700 Digital Camera Logo
474 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
power saving setting think accidental
  • Cameras
