20 Most Recent Lexar Professional High-Speed 1GB Secure Digital Memory Card Questions & Answers
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
I am using their products and never hand a major problem what so ever. The thing looks to maybe you got a bad file download. This can happen especially if you’re on wifi. Not sure what your hook up is so:REMOVE THE CURRENT FILE – UNLESS A DISK CAME WITH IT – THEN LOAD THAT SOFTWARE FILE – AND THEN UPDATE IF YOU CAN. OR – Just remove the file you have – remove the reader first – then remove the file – then clean it up with CCleaner. What CCleaner does is tidys up the registry so that when you Reload the new driver there’s no confusion –like the program seeing there is part of it already there. Anyway – in Green below is the direct contact with LEXAR. –You can chat with a rep at lexar dot com too – they are friendly and if you don’t like one – hang up and go back - - I wish I could tell you more but as I am sure you know this is very rare and might just fix via new software run and a reboot. It is probably just an anomaly. Remove and Reinstall or just install the link below with the ***** on it -
driver link - http://www.lexar.com/drivers/files/Drivers/Mac%20Driver_1.1.4.dmg.zip
> how to install - http://www.lexar.com/pdf/508_60862_Rev_A_ExpressCard_QSG.pdf
support@lexar.com
call at (510) 413-1275 during regular business hours, 7 a.m. to 5 p.m. PST, Monday to Friday.
Thanks for choosing FIX YA
Lexar... | Answered on Jun 23, 2010
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Lexar... | Answered on Mar 09, 2010
insert it in your pc.
right click after it appears on your computer. and click format or erase.
if these options are not available, delete everything from it.
Lexar... | Answered on Jan 20, 2010
you can download music using a program like limewire.
limewire.com i think is the website. then copy them to the sd card.
(you may have to get a sd card reader for your computer if you don't got one so you can buy pass your camera completely)
Lexar... | Answered on Nov 06, 2009
To connect the SD memory card to the computer you need a USB memory card reader. Plug the SD memory card into the USB card reader and then plug the card reader into the computer's USB port.
The computer will see this as an external memory card, you can then click on this memory card (it maybe the D or E or F drive) and select the music files from your computer then copy and paste your music files to this memory card. I presume the music files you need to copy are MP3 or MP4 files.
check whether u have installed USB controllers & drivers.
If nothing happens then do this. go to Start--> Run and type "devmgmt.msc" without quotes and enter. Then device manager will open , now connect ur memory card and look for scan for hardware changes menu . click that and scan . now u will find if any new hardware components are fixed to your computer or not. Then your memory card will be detected.
Lexar... | Answered on Aug 09, 2009
Honestly, it is most likely a defective memory card or not compatible with your camera. Sorry.
Lexar... | Answered on Apr 21, 2009
You may need Administrator privileges on your computer.
Plug in flash-drive.
Allow time for Windows Explorer to read it.
Run AV scan if suspect.
To get a list of attributes:
Launch Start > Run > CMD.
From the command console enter
attrib F:
(or whatever the drive letter is for your flash).
to redirect output to a text file enter (example)
attrib f:>%homepath%\flashatb.txt
From the list you should see [H]idden, [S]ystem or [R]ead only attributes for write-protected files.
You can also do it via Win Explorer by right-clicking the drive icon.
Remove all above attributes.
As a last resort, you can full-format the entire flash via explorer.
Which should wipe all files / folders on the drive.
Lexar... | Answered on Jul 05, 2018
does the card contain important data? if not would formating it help? have you a computer you could plug the sd card into and see what windows makes of it?
http://en-americas-support.nintendo.com/app/answers/detail/a_id/452/~/general-sd-card-and-microsd-card-troubleshooting
check nintendo site and see if that helps.
Lexar... | Answered on Jan 29, 2018
There is a little tab on that unit that slides back and forth. If the tab is missing, you need to use a piece of scotch tape to simulate the tab.
Lexar... | Answered on Feb 10, 2017
plug the flash drive into a usb port
it will register on the desktop and will be recognized in the computer
and given a designation--- example:- drive h---
select what you want and save as --in h
or copy /paste to h
or if you have 2 screens click and drag to h in the computer section of the second screen
Lexar... | Answered on Oct 02, 2016
Please check this link. How to Use an SD Memory Card
Lexar... | Answered on Jul 15, 2015
http://www.lexar.com/support/product-support
Lexar... | Answered on Feb 11, 2015
Either there's a little switch on the side, or the card has failed.
The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Lexar... | Answered on Sep 20, 2014
Once the device is recognized by your computer, locate the icon for the drive and select it, right click and scroll down to the format option on the context menu. Be sure you don't format over a drive that has necessary files as formatting will erase all files on the drive. Choose the appropriate format for the system it will be used on.....Windows, Linux, Apple etc.... Often you will have other options, such as Quick Format (most appropriate) or Complete and Utterly Long Format (which - as you might infer - takes for freakin' ever!)
Lexar... | Answered on Sep 09, 2014
If using Windows system on a computer: Click start, then Computer then find the USB thumb drive you want to format, right click on the drive and then click on "Format" on the dialog box that appears.
Lexar... | Answered on Aug 28, 2014
Just plug it in and it should be recognized by Windows and assigned a drive letter.
Lexar... | Answered on Aug 19, 2014
Lexar Professional High-Speed 1GB Secure Digital Memory Card Logo
10 questions posted
Top Lexar Electronics - Others Experts
Joe Negus
Joe Negus
 Mike M
Mike M
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Lexar Electronics - Others
Most Popular Question
put music sd card digital
  • Electronics - Others
