An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard.May also be a defective card inserted into your motherboard.Try isolating the problem by removing all components until you just have motherboard and power supply and see if it turns on.
Check your power supply or the power supply source (outlet or UPS unit) as well as the power cord. Your system power source is not at the correct amp, voltage and may need replacing.
Constant powerorange
switch power groundYellow
illuminationGray
dimmerBrown
antenna trigger antenna pink
left front+ tan -gray
right front+ light green - dark green
left rear+ Brown - Yello
right rear+ Dark blue- Light blue
I have had three different laptops, last one an XPS from DELL which did the same thing. Replacing the battery solved all three laptops. How old is the battery you have in there now?
1st remove all PCI cards, see if anything changes. If no change\:
If the power LED is solid AMBER, replace the motherboard
If Flashing AMber, replace the power supply
