20 Most Recent Dell OptiPlex GX150 SF PC Desktop Questions & Answers
2answers
Fatal error on Inspirion Dell. Can't get it to boot at all now.
what problem.
all you said is MAfee disk is bad
1/13/2015 6:33:54 AM • Dell OptiPlex... • Answered on Jan 13, 2015
GX150 optiflex "setup utility" configuration
Craig, If I follow you correctly, you are asking what setting you should have in the BIOS to make it Boot again. Fastest solution is to return to the BIOS and use the option of "Load Setup Defaults". These are the settings that the Manufacture or the OEM Motherboard Manufacture would have used during setup. With any luck, that should allow the system to restore to booting status. I hope this helps.
6/23/2014 5:45:58 AM • Dell OptiPlex... • Answered on Jun 23, 2014
OPERATING SYSTEM. That would be Windows. You are in BIOS Setup, and shouldn't be in there.Computer OFF. (Press the Power On button, and hold it for 10 seconds until the computer turns off; if it is on)Press the Power On button, and hold it in. Hold for a count of 10 seconds. let go. Do this same procedure 2 more times.If the Power On LED light blinks, when you press the Power On button for the third time; hold for ten seconds, let go; do it again.Keep pressing until the Power On LED light doesn't blink on.This resets CMOS Error Codes, and resets BIOS Setup back to the factory default settings.Operating system error is solved by installing the Restoration Disk/s, and when asked choose Repair. (Non-Destructive Installation)If this doesn't solve the problem, you have a bad harddrive data cable, or a bad harddrive.Regards,joecoolvette
11/21/2012 5:41:54 PM • Dell OptiPlex... • Answered on Nov 21, 2012
3answers
When i turn my dell
my dell GX 620 pc show orange light and refuse to boot up
5/27/2012 5:34:34 PM • Dell OptiPlex... • Answered on May 27, 2012
Please can you tell me the components of the following chipsets. north bridge,south bridge and I/Out put chipset
For the Dell Optiplex GX150 Desktop PC?http://support.dell.com/support/edocs/systems/opgx150/en/ug/specs.htmMotherboard chipset: Intel 815ENorthbridge chip: Intel 82815Southbridge chip: Intel 82801BAhttp://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_II.2FIII_chipsetsUnder the subheading - Chipset - scroll down with your eyes to -815ELook to the right. You will see - 82815 - under - Part Numbers.That is the Northbridge.To the right of that, you will see - ICH2 - under Southbridge.Scroll the page down, until you come to the BOLD heading - Southbridge 8XX chipsets.You will see ICH2 is Intel part number - 82801BAThe I/O controller hub is in the Southbridge chip.I do not know what the Super I/O chipset is.[ The Northbridge chip should be under a finned Heatsink. If so, you will not be able to see the Intel part number.Looking at the motherboard as a map, with the Processor to the Top, and Ram Memory slots to the Right, the Processor is NORTH.(Ram Memory slots are to the EAST)Coming down the motherboard, the Northbridge chip is under the Processor.Come down further, and slightly to the right, and you will see the Southbridge chip.It has Intel 82801BA on it, with other Intel information ]HOWEVER, here is a list of Super I/O chipsets,http://web.archive.org/web/20070929033214/http://www.esupport.com/techsupport/award/superio.htm[ It comes up to the Wayback Machine. Wait a couple of seconds, and the Super I/O chipset page will come up ]If this is a general question about the Northbridge chip, Southbridge chip, and Super I/O chipset;Motherboard diagram,http://en.wikipedia.org/wiki/File:Motherboard_diagram.svgCPU stands for Central Processing Unit. Another term used is Microprocessor, or simply Processor for short.The Processor communicates with the Northbridge chip, through the Front Side Bus. (FSB)The Northbridge chip communicates with the Southbridge chip, through the Internal Bus.The Southbridge chip communicates with the Super I/O chipset through the LPC Bus. (Low Pin Count Bus)The Northbridge chip handles the faster capabilities of a computer.It handles the Processor, Ram Memory, and HIGH-speed graphics.AGP (Accelerated Graphics Port), and PCI-Express, are HIGH-speed graphics.A graphics card inserted into a PCI slot, or Integrated Graphics, is NOT high-speed graphics. This is handled by the Southbridge chip.The Southbridge chip handles the slower capabilities of a computer.IDESATAUSBEthernetand Audio. (Sound)This is more information on the Northbridge chip,http://en.wikipedia.org/wiki/Northbridge_%28computing%29For more information on the Southbridge chip, simply left-click on the blue - southbridge, in the end of the first sentence. (....the other being the southbridge)You can also search the following in Wikipedia, by typing them in the search box to the upper right, and clicking on the magnifying glass icon.Northbridge (computing)Southbridge (computing)Front-side busInternal busLPC busSuper I/O chip, and so on.For additional questions please post in a Comment.Regards,joecoolvette
5/15/2012 12:01:36 AM • Dell OptiPlex... • Answered on May 15, 2012
Dell OptiPlex GX150 no display no sound with yellow led
Hi, just pull out your memory card and clean it with an eraser. And insert it tightly again and don't forget to clean also the memory bank.Hope it will help you.
3/27/2012 10:26:33 AM • Dell OptiPlex... • Answered on Mar 27, 2012
No sound no display
just install motherboard disc for sound and see whether your connecting wires are correctly working or not
3/27/2012 7:59:22 AM • Dell OptiPlex... • Answered on Mar 27, 2012
2answers
I have tried everything Ctrl F11, Ctrl F9, Ctrl F8
Im not sure that you understood the concept of resetting the hdd...this can be done only by formatting ...and from the windows you can not format but the partitions(drives) that not contain the windows installation ...to be able to format all partitions you have to use a installation cd with the operation system ( a boot-able one ) ..and boot from cd ...by selecting this operation from Bios settings ...and go along with the clean installation not from the recovery partition or cd ...
after you get along with the clean installation and formatted the hdd and remake the partitions ...and finished the installation of the operating system ...than you can use the recovery cd to install the drivers and the factory settings and programs .....
another easy way to do that ..is to hook it on another computer ...and just format it from windows...this will erase it clean ..and you will have to reinstall the OS after that ...
11/18/2011 4:45:27 AM • Dell OptiPlex... • Answered on Nov 18, 2011
I get a solid orange
Motherboard failure, most likely, possible expansion card issue
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
5/20/2011 12:05:39 PM • Dell OptiPlex... • Answered on May 20, 2011
I get a blinking orange
It sounds like a power failure.
If it is plugged into a surge protector, try resetting it. In the Dell manual, it says, "if the power light is blinking amber - The computer is receiving electrical power, but an internal power problem might exist. Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).Ensure that the processor power cable is securely connected to the system board (see page 73)."
There is another thread on FixYa that might be of some use: http://www.fixya.com/support/t274632-dell_gx150_power_light_flashing_orange.
Finally, I checked a Dell forum and found this discussion: http://en.community.dell.com/support-forums/desktop/f/3514/t/17794576.aspx.
If you do need to replace the power unit, I found a replacement part athttp://www.discountelectronics.com/index.php?l=product_detail&p=2168.
If you are not comfortable replacing the part yourself, you can use a PC repair service, such as the Geek Squad. It might be worth getting a second opinion.
Thank you for using FixYa!
5/10/2011 2:05:30 PM • Dell OptiPlex... • Answered on May 10, 2011
I have Dell GX 150.
Go to www.support.dell.com andselect "I'm looking for drivers and downloads". If you don't have theproper version of Adobe you will be prompted to install it. Once installedreturn to "drivers and downloads" and enter the "servicetag",(serial number) of the computer. Dell keeps a listing of driversfor every customer's computer they sell.
5/9/2011 12:39:17 AM • Dell OptiPlex... • Answered on May 09, 2011
Installing driver CD for dell
have you chaned your microsoft windows ??? if yes.the problem is compatibility.
bestsof4u-2.tk
3/28/2011 1:14:19 PM • Dell OptiPlex... • Answered on Mar 28, 2011
Does desc top computers come with Quad Processors?
While some desktops come with quad-core processors, unfortunately the Dell OptiPlex GX150is not one of them.
2/28/2011 3:11:43 PM • Dell OptiPlex... • Answered on Feb 28, 2011
2answers
Replaced hard drive and now
Did you set the jumper(s) on the new drive to match the settings on the old drive (usually CS or Cable Select)?
Did you double check the power connector was snug on the new drive? You may also want to double check the connector on the motherboard, SF systems are cranky about moving around, and mave have unseated the motherboard end of the cable.
9/8/2010 10:13:04 AM • Dell OptiPlex... • Answered on Sep 08, 2010
7answers
Dell GX150 - Power light flashing orange
A blinking Yellow power light means a dead power supply. Whats with all the overly complicated answers. Every Dell I've ever worked on that had that problem was the power supply and I've fixed hundreds of them.....
8/11/2010 4:50:20 PM • Dell OptiPlex... • Answered on Aug 11, 2010
Does the f11 key on my dell gx150 do a factory
try ctrl+F11
6/11/2010 11:07:44 PM • Dell OptiPlex... • Answered on Jun 11, 2010
Can i do a system recovery on a dell GX150
If you contact microsoft with the cd key on your computer they can give you a cd free. As long as you provide the key on your computer!
6/11/2010 10:44:04 PM • Dell OptiPlex... • Answered on Jun 11, 2010
Dell GX150 Restore
no, you need a repair or mabye at an extreme a clean install.
2/23/2010 7:13:30 PM • Dell OptiPlex... • Answered on Feb 23, 2010
Power supply and processors fans spin then stops
There are a few possible sollutions, either your motherboard is faulty the processor, or the processor/motherboard settings.Here are some steps to follow to acertane which problem you have.
  1. Unplug the computer from the mains and take the side panel off remove any cables connected to the motherboard,exept the power cables, blow away any dust built up on the board and reboot the mechine.
  2. Turn the computer off and remove the little round lithium battery found on the motherboard for about 30 seconds and then replace, any settings that have been changed in the bios will return to factory defaults.
  3. If still the same problem persists and if you are confident enough to take the fan off the processor do so, there should be clips either side of the fan to take it off and expose the processor, with a dry cloth rub away any white coolent from the underneath of the fan and the top of the processor. you can by cooling compound from any pc store, reapply the new compound and reapply the fan to the processor and clip it back down. Reboot mechine Still nothing you could take it to your local pc store and ask them if they have a tested working processor that you could try.
  4. If all else fails you could have a faulty motherboard, find out what processor you have and memory the system uses and purchase a new mother board you could try here: www.ebuyer.com.
1/29/2010 3:01:40 PM • Dell OptiPlex... • Answered on Jan 29, 2010
2answers
When laptop switched on dell logo appears then
restore your computer using the restore partition or restore cds, you can try to do a repair install of windows but sometimes that can hurt rather than help. if you want to f ind out the reason why hit f8 at boot and scroll down to 'do not restart computer after system failure' and hit enter, when it fails again it will give you a stop code looking similar to 0x00000000 that will give us a little better idea of what the issue is. If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
11/21/2009 10:57:31 PM • Dell OptiPlex... • Answered on Nov 21, 2009
Computers & Internet Logo
Popular Tags
37 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
OptiPlex Dell
  • OptiPlex Dell
Most Popular Question
when turn dell
  • Computers & Internet
