Mod #FGF379WJCB
You would definitely want to seek out a professional technician to diagnose the unit. Gas units are very dangerous if you are not use to working on them. You could have a slow gas connection or flow, a faulty valve, or bad ignition. All would absolutely need a professional to diagnose and repair, this is not a typical DIY job.
SOURCE: Frigidaire Range - Oven does not work
If your ignitor looks real dull orange then that is what is wrong. It needs to be bright as the sun or it is weak.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Kenmore gas stove. Oven burns big flame which soots
The manifold needs to be cleaned and adjusted could have rust etc in it Not a good thing to do yourself unless you know what you are doing
SOURCE: How to lite a pilot lite on a frigidaire "Gallery" gas stove?
wet sparkers, let them dry out good
SOURCE: Frigidaire FGF316WGSF GAS range oven won't work.
check this out
SOURCE: Frigidaire Gallery Series ES340 ceramic-top range:
The manual is missing a step. After pressing Clean or Quick clean you need to press the ^ button once.
