20 Most Recent Frigidaire FGB24S5A Gas Single Oven Questions & Answers
you most likely have a bad oven ignitor...if you see an orange glow under the oven panel that is your ignitor trying to come on....but if it is weak it will not open the gas valve.....acess the ignitor and replace it
Frigidaire... | Answered on May 20, 2019
it's still under warranty for 1 year but by him working on it you could have voided the warranty i would call whoever you bought it from or call the factory and tell them it's under a year old what will you do for me.
Frigidaire... | Answered on Feb 08, 2018
check ignitor
Frigidaire... | Answered on Oct 08, 2017
Most error codes can be cleared just by unplugging the unit and re-plugging it back in. If this doesn't clear it then I would go to Frigidaire's web site and search for tech support. I did some checking with Frigidaire and they don't show a code f27 I was wondering if maybe it was showing two codes F2 and F7? so it might look like F2,7?
Frigidaire... | Answered on Nov 18, 2015
some units will need to be adjusted if you live in a high altitude above 3000ft.
Frigidaire... | Answered on Nov 03, 2015
There are MANY appliance parts websites. They are pretty much the same. Just check the prices, including shipping, for the best deal.
Frigidaire... | Answered on Sep 20, 2015
I would say yes. I took my cover off to change the bulb and never replaced. Works fine.
you have a short and need to check it ASAP SHOULD BE ABLE TO VISUALLY INSPECT IT
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Frigidaire... | Answered on Apr 17, 2015
GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
when the power returned there would have been a high voltage which would have blown out the fuse cange the fuse and on it
Frigidaire... | Answered on Dec 06, 2014
Your oven valve won't open all the way
Thank you for your post, Friend.
If you are receiving an error code F11 on your Frigidaire range, it typically indicates that your range has detected an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, at this moment I would suggest connecting a professional to proceed further. Most likely the EOC (Electronic Oven Control) or RTD Probe (Resistance Temperature Detector) will need replacing. I hope this information helps to some degree. - Z
Frigidaire... | Answered on Aug 19, 2014
Good Afternoon Friend, this is Z. I am happy to assist you!
I see that your question is listed under Frigidaire Gas Single Oven (FGB24S5A) and that you are looking for the manual. I have successfully located the Owner's Guide. However, if you need a different manual, please provide me your model number. You can typically locate the serial tag (which lists your model number) on the front of the oven, on the left side, as you open the door on a wall oven. If you have a range, you may find the tag in the storage drawer, on the right side. Hope this helps!
Frigidaire Manual Search Results
Frigidaire... | Answered on Jul 17, 2014
Good Morning Annette,
I see that you are having trouble with setting the temperature of your oven on your range, model# FGB24S5A, after a power failure. I also see that you have reset your appliance by unplugging it and are receiving an error message of SAG or 5AB. I have looked into the model number that you have listed and it shows as a wall oven. I also do not show either of those error codes you have shown. If you can please get me the model number off your range, so I can better assist. The model number will either be right inside the oven on the back of the door or it may be located inside the bottom drawer. Looking forward to hearing from you.
WP
Frigidaire... | Answered on Apr 25, 2014
Hi RDWSR, this is AP. Thank you for your post.
Regrettably, you are not able to adjust the timer tone on your Frigidaire wall oven.
Frigidaire... | Answered on Mar 07, 2014
Frigidaire FGB24S5A Gas Single Oven Logo
166 questions posted
Top Frigidaire Ovens Experts
Marvin
Marvin
Bruce Denton
Ekse
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Ovens
  • Frigidaire Ovens
Most Popular Question
adjustment timer tone frigidaire gas
  • Ovens
