Sony VAIO VGC-LV180J 24-Inch All-in-One PC  Logo
Bruce Arbogast Posted on Dec 30, 2017
I have a Vaio all in one. I had a USB flash drive in a port, and when I removed it the screen on the computer went blank. I have put the system to sleep , the start up works fine, the screen works, but after about 5 seconds goes blank again. This will also occur on a reboot of the system. Is the screen shot?
Mike Cotterill
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Apr 10, 2019
Mike Cotterill
Contributor
Level 1:
New Friend:
Answers
35
Questions
0
Helped
5587
Points
56
Try to start the system in safe mode and see if that works if so it is not the screen.
To enter safe mode press F8 during boot up after the bios screen.
1 Related Answer
Anonymous
  • 49 Answers
  • Posted on Oct 17, 2012
SOURCE: I have a Vaio all in one. I had a USB flash drive in a port, and when I removed it the screen on the computer went blank. I have put the system to sleep , the start up works fine, the screen works, bu
OS problem check whether it's update or not.. and activate the OS...
How to unlock partition on flash drive
USB flash drives are small, convenient storage drives. Place data such as pictures, photos and text on them quickly and efficiently and then carry it to another computer for copying to its hard drive.
A USB flash drive that has security enabled in it must be 'unlocked" before it can be used, which becomes difficult if the password has been lost. Because the security on the USB flash drive is rudimentary, a number of methods, from built-in software to optional programs, can remove the security so that the drive can be used.
Plug the USB connector of the USB flash drive into a USB port on the PC. Right-click on the icon of the USB flash drive when it appears on the desktop of a Windows-based computer. Select "Format" from the pop-up menu. Follow the command prompts in the window that appears to format the USB flash drive. Click "Done" in the confirmation window when it appears. The USB flash drive can now be used because the security has been removed from its storage space. Plug the USB connector of the USB flash drive into a USB port on the Mac. Double-click on the Mac's Disk Utility program, which comes free with the OS X operating system and is in the "Utilities" folder on the hard drive. Select the icon of the USB flash drive in the left column of the Disk Utility program's main screen. Select the "Erase" tab at the top of the Disk Utility program's main screen. Click on the "Format" check box on the right side of the Disk Utility program's main screen. Select "Fat (32)" from the drop down menu below the "Format" check box. Click "Format" at the bottom of the Disk Utility program's main screen. Click "Format", again, in the confirmation box that appears. Quit the Disk Utility program when the formatting is done. The USB flash drive can now be used because the security has been removed from its storage space. Download a password protection program to the computer's desktop; for example, the free TrueCrypt password protection program (see the link Below). http://www.truecrypt.org/downloads Double-click on the icon of the password protection program when it has fully downloaded. Follow the command prompts to install the program onto the computer's hard drive. Restart the PC after the installation has been completed. Double-click on the password protection program to launch it. Wait for the password protection program to recognize the USB flash drive and display disc letters for the drives attached to the computer in the left column of its main program screen. Plug the USB connector of the USB flash drive into a USB port on the computer. Wait for a letter to appear in the left column of the password protection program's main screen. Use the mouse to click once on this letter which represents the USB flash drive. Click on the "Volume" or "Volume Tools" button to open a new window. Click on the "Next" button in the new window. Erase the password in the "Password" column of the new window that appears. Erase the password in the "Confirm password" column. Click on the "Next" button to go to a new screen. Select "Traveler Disk Setup" from the drop down menu below "Tools" at the top of the password protection screen. Click on the "Open Explorer window for mounted volume" check box in the new window that appears. Click the "Create" button at the bottom of the window. Click the "OK" button on the confirmation window when it appears. Quit the password protection program. Drag the icon of the USB flash drive to the Trash or right-click on it and select "Eject" from the pop-up menu. Remove the USB flash drive from the computer's USB port. Plug the connector of the USB flash drive back into the computer's USB port. Double-click on the icon of the USB flash drive when it appears on the desktop to open its window now that the security password has been removed. Plug the USB connector of the USB flash drive into a USB port on the PC. Go to "Start" and select "Run" from the pop-up menu. Enter "regedit" into the text column that appears and press the "enter" key to run the registry editor. Press the "Browse" button on the registry editor's main screen and navigate to the following path on the computer's hard drive: "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies" Click "OK" to close the window. Double-click on the "WriteProtect" text that is in the right column of the registry editor's main screen. Enter "O" into the "Value Data box" in the window that appears. Click on the "OK" button to close the window. Quit the registry editor program. Restart the PC. Double-click on the icon of the USB flash drive that is on the desktop to open its window and access the files now that the security write protection has been removed.
Hope this helps.
I can't open because of the paSSWORD IN IT.
Hope this helps.
Un lock my pasword
Which is it a 2 gb cruzer or 1000 gb ??
Plug the USB connector of the USB flash drive into a USB port on the PC. Right-click on the icon of the USB flash drive when it appears on the desktop of a Windows-based computer. Select "Format" from the pop-up menu. Follow the command prompts in the window that appears to format the USB flash drive. Click "Done" in the confirmation window when it appears. The USB flash drive can now be used because the security has been removed from its storage space. Plug the USB connector of the USB flash drive into a USB port on the Mac. Double-click on the Mac's Disk Utility program, which comes free with the OS X operating system and is in the "Utilities" folder on the hard drive. Select the icon of the USB flash drive in the left column of the Disk Utility program's main screen. Select the "Erase" tab at the top of the Disk Utility program's main screen. Click on the "Format" check box on the right side of the Disk Utility program's main screen. Select "Fat (32)" from the drop down menu below the "Format" check box. Click "Format" at the bottom of the Disk Utility program's main screen. Click "Format", again, in the confirmation box that appears. Quit the Disk Utility program when the formatting is done. The USB flash drive can now be used because the security has been removed from its storage space. Download a password protection program to the computer's desktop; for example, the free TrueCrypt password protection program (see the link in Resources). Double-click on the icon of the password protection program when it has fully downloaded. Follow the command prompts to install the program onto the computer's hard drive. Restart the PC after the installation has been completed. Double-click on the password protection program to launch it. Wait for the password protection program to recognize the USB flash drive and display disc letters for the drives attached to the computer in the left column of its main program screen. Plug the USB connector of the USB flash drive into a USB port on the computer. Wait for a letter to appear in the left column of the password protection program's main screen. Use the mouse to click once on this letter which represents the USB flash drive. Click on the "Volume" or "Volume Tools" button to open a new window. Click on the "Next" button in the new window. Erase the password in the "Password" column of the new window that appears. Erase the password in the "Confirm password" column. Click on the "Next" button to go to a new screen. Select "Traveler Disk Setup" from the drop down menu below "Tools" at the top of the password protection screen. Click on the "Open Explorer window for mounted volume" check box in the new window that appears. Click the "Create" button at the bottom of the window. Click the "OK" button on the confirmation window when it appears. Quit the password protection program. Drag the icon of the USB flash drive to the Trash or right-click on it and select "Eject" from the pop-up menu. Remove the USB flash drive from the computer's USB port. Plug the connector of the USB flash drive back into the computer's USB port. Double-click on the icon of the USB flash drive when it appears on the desktop to open its window now that the security password has been removed. Plug the USB connector of the USB flash drive into a USB port on the PC. Go to "Start" and select "Run" from the pop-up menu. Enter "regedit" into the text column that appears and press the "enter" key to run the registry editor. Press the "Browse" button on the registry editor's main screen and navigate to the following path on the computer's hard drive: "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies" Click "OK" to close the window. Double-click on the "WriteProtect" text that is in the right column of the registry editor's main screen. Enter "O" into the "Value Data box" in the window that appears. Click on the "OK" button to close the window. Quit the registry editor program. Restart the PC. Double-click on the icon of the USB flash drive that is on the desktop to open its window and access the files now that the security write protection has been removed. Hope this helps
2answers
How to format usb that says it has 8mb capacity.
To Format Any Flash (USB) Drive
WARNING: This will permanently remove ALL data from your flash drive.
1) Insert the flash drive into a working usb port on your Windows PC.
2) Open "My Computer" in Windows XP or eariler OR "Computer" in Windows Vista/7
3) Right click on the Flash Drive (Usually labeled "Removable Disk")
4) Click "Format..."
5) Ensure that file system is "FAT32", Volume label is a name of your choosing, and that "Quick Format" is unchecked
6) Click "Start"
7) Windows will warn you that all data is about to be deleted. Click OK.
8) Once the format is complete, Windows will produce a pop-up window telling you so.
You now have a blank flash drive.
4helpful
2answers
I installed Dell Vostro 1000 System BIOS, v.2.6.1, A04 on myDell Vostro 1000. When it was finished the screen went black and it won't start. Now what? is the computer ruined?
Yep I did the same. Finally recovered using the link shown below.
http://hotfile.com/dl/113520903/05689ed/VOSTRO1000_CRISDISK.ZIP.html
To Create a Crisis Recovery USB you must use a Win XP system
Note: Running XP through compatibility more in Win 7 will not work
1. Insert Blank USB Drive
2. Open "CRISDISK" folder
3. Open "WINCRIS" application
4. It should detect the USB Drive
5. Click "Start" Button
WINCRIS should create the USB recovery drive
6. For Crisis recover, be sure to Power drain system.
A. Remove Battery
B. Depress power button for 10-15 sec.
7. Insert USB drive into USB port.
8. Hold END button while plugging in power cord in system
9. Continue to hold END and depress and release the system power button.
10. Continue holding END until USB drive begins to flash and a beep is heard.
11. System may remain blank as it enters recovery mode - Anoying Beeping will be heard - Beeping will stop and FANS will function Another series of Beeps will be heard
12. System should complete recovery in 5-10 min. If system has not powered down in 15 min, power down by pressing the power button
Good luck Dean/Steve
How to solve usb not reconized error in sony vgn-s36gp?
Hello
Disconnect the flash drive from your computer, then plug it into a different USB port. On occasion some USB ports do not detect inserted equipment (either because the port is damaged or because the flash drive is not supported by the particular connection).
Connect the flash drive after the computer has powered on. If you plug the drive into the computer before starting the system, the computer may not detect the USB device.
Open an Internet browser and navigate to the drive manufacturer's website. Although most USB flash drives are plug-n-play, the computer may not have the appropriate drivers installed, which means you must install the driver before the system can use the flash drive.
Select the "Support" option, then choose "Drivers and Downloads". Click on the model of flash drive you are using, then the operating system. Click on the driver download link and wait for the driver to download to the computer. Double-click the downloaded file to load the installation wizard. Accept the license agreement, then follow the prompts to install the driver. Restart the computer and the system is ready to use the USB flash drive.
VAIO desktop does not recognize Sandisk flash drive
Most probably you have a drive letter conflict? If so, right click "My computer" choose "Manage" and locate "Disk management" - here, in the middle lower panel, you should be able to find your usb-memory stick, right click it and assign it a drive letter that you're sure is not in use.
Pen drive not working
If your usb port is working properly your computer should pick up the the pen drive as soon as you put it in the usb port if not goto add and remove hardware and check to see if the diver is up to date .hope this works for you let me know ok
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
