HP Compaq nc6120 Notebook Logo
Posted on Sep 12, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fix wifi button - HP Compaq nc6120 Notebook
Anonymous
Level 3:
  • Master 1,179 Answers
  • Posted on Sep 13, 2012
Anonymous
Master
Level 3:
Answers
1179
Questions
Helped
246370
Points
3035
A computer technicain may have a spare button from another unit available. Contact computer technicians in your area.
Take care!
damnor01
My gigacet ... the on and off button won't stay on on for wifi
May Ur WiFi connector is broke inside Ur device
2answers
How to fix Brother printer WiFi setup?
  1. Steps to Reset the WiFi Connection on Brother Printer
  2. Firstly turn on your Brother printer.
  3. Then press the Menu button on the control panel of the printers.
  4. Now select Network and press Ok.
  5. After that select Network Reset and press Ok.
  6. Press Reset and then select Yes.
https://techsupportexpert.com/brother-printer-not-connecting-to-wifi/
How to reset the WIFI connection on your Brother printer
  1. Press the 'menu' button on the control panel (if you have a touchscreen select 'Settings' or 'Spanner & Screwdriver icon' then select 'All settings')
  2. Using the arrow keys, scroll down to 'Network' then press 'OK'
  3. Using the arrow keys, scroll down to 'Network Reset' then press 'OK'
  4. Press '1' to say yes.
http://atyourside.co.nz/how-tos/reset-your-wifi/
2helpful
3answers
How do i fix iPhone is not connecting to wifi?
I had same issue since yesterday and found my problem for iphone won't connect to wifi fix by reading the article http://www.fixotip.com/iphone-wont-connecting-wifi-router/
Why Does My Iphone won Connect To wifi Router Fixotip it may help you also.
Jan 02, 2018 • Cell Phones
How do i fix Sound has stopped working in my Toshiba Laptop
This my sound simple, but is it muted through the speaker icon (a red line through it) or by inadvertently hitting a button on he laptop itself? The wifi on many laptops can also be turned off by hitting button on the keyboard, the wifi light or led itself.
a model number can be helpful. I also have ability to remote in to fix it if I is online.
How to fix wifi
sometimes it helps to just make a restart of the iPad to get things sorted....
Restart iPad: Press and hold the Sleep/Wake button until the red slider appears.
Slide your finger across the slider to turn off iPad. To turn iPad back on, press and hold the Sleep/Wake until the Apple logo appears.
It says wifi unavalible
Turn Airplane mode off. Airplane mode shuts off any radio signals that would interfere with airport communications including wifi.
Neo wifi
normally to turn off the wifi, they some button with LED int the right corner. Press the button and see what happen. Otherwise, you can go to control panel use the system restore, and put some date that you know was working good.
or Restart the computer HOLD the key CTRL +f11 or f12 depend of your model ,etc and restore to the factory default, and fix it.
God bless you
Wifi button does not work on my iphone 4s
Try to reset all your settings - before doing this Backup all data
2nd - try to restore it (Warning) You must have a Factory Unlock before Restoring
3rd - if those Solution doesn't fix your problem better visit your nearest apple center. It's a hardware proble - wifi module
2helpful
Wifi grey area
Here is a way that solved the problem for me.
Downgrade the ipod touch to firmware 1.1.4. You have to put your ipod into DFU mode ('not recovery mode) and you have to have an itunes version that supports this old firmware. 7.5 oder 7.7 i think.
to load your own firmware you simply hold the shift-button while you push the restore button.
After you have firmware 1.1.4 on your ipod touch, download the jailbreaker "Ziphone". This programm has the option to fix the "no Wifi" problem. Look in the advanced options.
In my case, this was the only thing that solved the problem. I tried restoring it often but nothing worked.
After Ziphone fixed your Problem, you can update the Touch to the latest firmware. Wifi was still working, at least for me
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
