Sewing Machines Logo
Melanie Graysmith Posted on Aug 27, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Foot pedal not working
My machine is working but the foot pedal seems dead. When I turn the machine off and on again I heard a sound indicating the machine kicked in and I was stitching just before it stopped working, so believe it is the pedal. When I first put the machine on today to sew, there was no action and pedal seemed off, so thought it was a connection. When i restated machine it sewed, but then after stopping to do something, then starting again with a new stitch, no movement, but machine made OK sounds. The foot pedal feels "dead." Is that possible? Do foot pedals need to be replaced after a while? Thanks
Debbi's Sewing Machine Repair
Level 3:
  • PfaFF Master 7,365 Answers
  • Posted on Aug 28, 2012
PfaFF Master
Level 3:
Answers
7365
Questions
Helped
1744579
Points
19451
Yes, it is possible that the foot pedal can go out,, it would be a good
idea to have the foot pedal checked at a repair shop to see for
sure
Testimonial: "I went to sewing machine store today and the pedal checked out as dying, so ordered a new one. Thx again!"
5 Related Answers
Anonymous
  • 1116 Answers
  • Posted on Mar 20, 2010
SOURCE: I have a Phaff 2140. I was having a problem with
Call the place you had the machine serviced and tell them they did not get it fixed; you need to have them to look at it again - as you wait and at no additional charge unless a part has to be replaced.
Anonymous
  • 1116 Answers
  • Posted on Feb 22, 2010
SOURCE: Pfaff 7530/ electronic problem?
Where has it been for ten years? This could have a big affect on an electronic sewing machine.
Take the machine in to a sewing machine shop for service.
Anonymous
  • 96 Answers
  • Posted on Dec 13, 2009
SOURCE: Pfaff210 sewing machine foot pedal
google the manufacturer and see if you can get one by mail from ITALY
SewTechWayne
SewTechWayne
  • 186 Answers
  • Posted on Feb 01, 2009
SOURCE: sewing design thread breackage
Assuming that the timing, needle clearance, position finger and needle plate position are all properly set you can try the following:
1. Oil the hook (use Pfaff hook oil, it is a lighter weight than the normal white oil used on sewing machines).
2. Check the hook tip and flank for damage, buff out if possible.
3. Check the needle plate for damage and buff out.
4. Replace the needle.
This is a great machine and is worth keeping up, Pfaff doesn't make the all metal hook anymore which is a shame.
good luck!
Anonymous
  • Posted on Oct 03, 2010
SOURCE: Pfaff 1471 will not run. Thanks to gherna1 for
Have the same problem. Did you ever find a solution
1helpful
My matching viking 6570 is suddenly not working it does not move
I assume you are referring to a Viking 6570 sewing machine.
Ensure power is getting to machine is light working?, is the motor trying to move when you press the pedal? if you hear noise that it is trying to move the mechine is blocked try gently turning by hand if still does not move then machine has mechanical issue or is blocked with threads or dust
When was machine services or oiled as per handbook?
If there is no no sound from motor but machine has power and turn normally by hand this would indicate either the foot pedal switch or the motor is broken and probably needs replacement. Try with another foot pedal first if possible
Elna 9000 foot pedal
it sounds like you may have a connection problem with the plug on the sewing machine and the foot pedal, it would be a good idea to have them checked.
Serger repairMy Viking 910's motor has decided to sound like it's still running when I've taken my foot off the foot pedal. (It sounds as if you are applying the lightest of pressure) I have taken the...
When this happens unplug the foot pedal and see if it stops. That would suggest it is in the pedal. Does the machine try to turn when this happens?
The foot pedal makes noise, but won't turn bobbin.
only having the machine check at a sewing machine repair shop can say for sure
2helpful
2answers
Foot pedal error
Yep same thing .....the thing is possessed started running by itself when I was at the iron. Dealer said never heard of such a thing and acted like it was me. Also will not stop sewing when take foot off pedal. Dealer charged me $95 to clean machine and said nothing wrong with foot pedal. Ugh. Has anyone replaced foot pedal and found the problem to stop properly?
2helpful
White 1600 SpeedyLock. Power, but foot pedal won't engage. Took foot pedal apart, mechanically looks fine-- computer board in there. Do I need a new foot pedal?
When stepping on the foot control, does the motor hum or anything? Or is dead silent? If it sounds like it's trying to do something, the serger probably needs to be serviced. If it's silent, you probably need a new foot control.
Lights turn on but foot pedal stays dead. Needle
If you know someone who is savvy in the mysteries of electricity, ask them to test the foot pedal to see if it is working and the socket on the machine to see if it is receiving power.
If you need a new foot control pedal - check the Internet for best prices - you will need the machine's model number.
If you take the machine to a dealer for service, ask what it will cost before making the trip.
The bench rate for just looking at the machine may not be worth it.
No matter how hard I press down on the foot pedal my needle speed is super slow. The needle position indicator sometimes shows up when the needle is down and the needle continues it slow speed even when my...
is the machine easy to turn by handwheel? if not it may be seizing and needs servicing.
if the machine is free to turn by hand it sounds like your foot control is in need of repair or replacement - see a tech.
scott.
2answers
Model 6010 Won't Stop Sewing
I would say that is the computer in hte machine
2helpful
2answers
Foot pedal dead, machine keeps sewing!
There is no suppressor in the foot control of a 425. Only the control unit, which may need to be replaced. If the machine accelerates to full speed, it may have a problem with the "stop right" board which tells the machine whether to stop with the needle up.
You could have several problems, so go see a qualified Husqvarna repairman. You may contact Husqvarna customer service to locate the best one in your area.
Top PfaFF Sewing Machines Experts
ExpressFiX
ExpressFiX
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
