20 Most Recent Janome Memorycraft 6500P Computerized Sewing Machine Questions & Answers
3answers
Hi I have a janome
Yes you can adjust the bobbin thread. Take your bobbin case out, look for the little red dot on top of case--under that is a small screw--get a very small screwdriver and adjust----CAREFUL-IT JUST TAKES A VERY, VERY SMALL TURN--JUST REMEMBER---"righty- tighty--leftty -loosey". Just remember how you turn it--if the tension need tightened, turn it slightly to the right and if you need to loosen the tension--turn it slightly to the left. I hope this works for you.
1/30/2020 11:54:31 AM • Janome... • Answered on Jan 30, 2020
2answers
Machine running very slow . Does it need serviced ?? Is it machine problem or foot pedal problem ?
take it in for a service as slow machines can be from thread and fluff jamming the shafts , foot control or motor problems
8/9/2016 12:27:39 AM • Janome... • Answered on Aug 09, 2016
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
1/26/2016 12:39:26 AM • Janome... • Answered on Jan 26, 2016
Oops! it is a Janome Memory Craft 6500, that I cannot figure out how to oil.
Don't stress. Open the acess door and put a few drops where the needle goes up and down and that's it. I personally think they over do and over stress oiling.
12/30/2014 11:55:46 PM • Janome... • Answered on Dec 30, 2014
HOW DO I FIX A FM PHASE ERROR ON MY JANOME 6500 MEMORY CRAFT
Check your Feed dog switch for raised or lowered positioning and reengage to either setting and rotate the hand wheel to reengage the gears properly. Cheers, Kelly San Diego, CA Embroidery Services
11/30/2014 4:19:09 PM • Janome... • Answered on Nov 30, 2014
How to time memory craft 7000
your manual should have directions if you don't have please us your search engine on your computer put in model + name+ number + manual + free
8/29/2014 5:47:11 AM • Janome... • Answered on Aug 29, 2014
Lcd screen no responding
Time to bring it in for repairs.
5/15/2014 8:22:49 PM • Janome... • Answered on May 15, 2014
0answers
2answers
My needle thread keeps breaking. I've tried
Are you sure you have got the top thread threaded correctly including the take up lever? Start at the thread spool and follow the thread all the way through the thread path checking that it is not snagging on anything enroute and that the thread is correctly through the tension device. Also tension dial should be on 4-5, if its higher this could be breaking the thread. YOu should not need to adjust top thread tension more than a half increment at any time.
Other possibility is that the bobbin holder under the needle plate has moved out of alignment and then the top thread is catching there as it goes around the hook.
If you check your manual it should give you instructions on removing the needle plate (2 screws need to come out), then you can lift the bobbin case out towards you, clean underneath with your little brush, then reinsert it. There are two little red marks on the right side of the bobbin case and a stopper, these need to be lined up. Then put in bobbin and rethread into tension spring, replace needle plate, bobbin cover, and test stitch.
Hopefully one of the above is causing the thread to break.
3/17/2014 6:06:44 PM • Janome... • Answered on Mar 17, 2014
0answers
0answers
0answers
0answers
0answers
0answers
TD init error code
Be the first to answer 1/16/2013 4:39:43 PM • Janome... • Posted on Jan 16, 2013Be the first to answer
While quilting I heard the machine hammer--I stopped it and changed out the bobbin to only only have the thread not pick up from the bobbin. Now I can not sew the the machine.
Remove and replace the needle (it is probably damaged now) Test stitch a seam. If you still have problems Check the timing of your machine.
9/19/2012 8:06:43 AM • Janome... • Answered on Sep 19, 2012
Free hand stitching
Drop your feed dogs, remove your normal foot... replace with embroidery or darning foot... or leave without a foot. stretch fabric in a hoop..... set your stitch.. and sew as you move the hoop.
7/27/2012 2:15:04 AM • Janome... • Answered on Jul 27, 2012
2answers
Foot pedal error
Yep same thing .....the thing is possessed started running by itself when I was at the iron. Dealer said never heard of such a thing and acted like it was me. Also will not stop sewing when take foot off pedal. Dealer charged me $95 to clean machine and said nothing wrong with foot pedal. Ugh. Has anyone replaced foot pedal and found the problem to stop properly?
4/9/2012 5:16:55 PM • Janome... • Answered on Apr 09, 2012
Janome Memorycraft 6500P Computerized Sewing Machine Logo
Popular Tags
52 questions posted
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Janome Sewing Machines
Most Popular Question
oops janome memory craft 6500 cannot
  • Sewing Machines
