20 Most Recent White Sewing Speedylock 1600 Mechanical Sewing Machine Questions & Answers
3answers
Threading my whites superlock 2500 serger
You can get sewing machine manuals online at sewingmanuals.com. I didn't see the superlock 2500 but there were other superlocks. They may thread the same way.
7/16/2022 2:10:51 AM • White Sewing... • Answered on Jul 16, 2022
I was sewing a minky
I think that you must have some of your fabric and lint in your machine. Take a brush ( I use a new paint brush and clean your machine looper areas really well, oil then Totally rethread, take your thread for each guide and treat it like floss going into all of the grooves so that they are seated properly. This should do it, getting your thread seated is the most common problem with overlockers not chaining.
1/31/2018 12:55:03 AM • White Sewing... • Answered on Jan 31, 2018
Why my white speedylock serger is not staying threaded. It was said the timing is broken, can it be repaired
Depends whether the thread is breaking or pulling out.Usually, timing causes the threads to miss stitches. And, yes, timing can be repaired.Remove ALL the thread from the machine and rethread from the beginning. Be sure to ALWAYS raise the presser foot when threading. This releases the tension disks so the threads will seat completely. However, it also helps to give each thread a little tug and sometimes the thread will pop when it seats.If thead is pulling out, be sure to pull a lot (at least 6") of thread tail through before beginning to stitch.If the thread is breaking, check that it is threaded correctly and that each thread is threaded in the proper order (usually upper looper first, then lower looper with the thread draped OVER the upper looper). Threading in the wrong order will almost guarantee it will not work. Also check that the tensions are not set too tight. Generally, to start out, set all the tensions at the midway point....
10/6/2016 4:39:33 PM • White Sewing... • Answered on Oct 06, 2016
Need instruction manual
Search the internet: Brand + Model + the word "Manual" ...
8/22/2015 5:45:16 PM • White Sewing... • Answered on Aug 22, 2015
How do I get a Service manual for an Industrial Sewing Machine
If the handwheel is really stiff and the machine is making awful noises, then your machine may need oiling. Don't know if this is the case with your industrial machine, but it may be something to consider.
2/23/2015 10:01:34 PM • White Sewing... • Answered on Feb 23, 2015
tip
Speedylock 1600 video
My wife picked up one at a thrift store for $20.00. She gave me the job of looking into a manuel for it. I think that the original video that came with it can be found on youtube at... https://www.youtube.com/channel/UCSo_kB9pRB6uPgVOp9wHtWg A copy of the manual can be found at http://www.hammerwall.com/Manuals/White/Description/1600/White%20SpeedyLock%20Differential%20Sewing%20Machine%20Manual/754_SL%201600%20x/ A review for it can be found at http://www.sewinginsight.com/other-brands/white-speedylock-model-1600-review/
Cutter on speedylock
Servicing the Timing is NOT a home fix
4/22/2014 7:44:40 AM • White Sewing... • Answered on Apr 22, 2014
Speedylock 1600 won't make chain.
Timing issue, take for a Service
4/22/2014 1:01:56 AM • White Sewing... • Answered on Apr 22, 2014
0answers
Serger parts
Be the first to answer 2/2/2014 12:38:56 AM • White Sewing... • Posted on Feb 02, 2014Be the first to answer
Why is my creations 3 sewing in reverse when the revrrse button is not lit
Push and hold the reverse button for 7 seconds and see if that fixes it.
1/31/2014 9:49:08 AM • White Sewing... • Answered on Jan 31, 2014
Creations 3 is sewing in reverse reverse button not lit
All serging machines run in reverse, the hand wheel turns reverse compared to regular straight stitch machines which run counter clock wise. I need more information, My email is [email protected].
1/26/2014 4:56:07 PM • White Sewing... • Answered on Jan 26, 2014
0answers
Broken screw
Be the first to answer 1/11/2014 7:15:41 PM • White Sewing... • Posted on Jan 11, 2014Be the first to answer
Kenmore 385 #3 thread breaks
Try removing thread #3 from the tension altogether. If this doesn't work, then try using a different spool of thread. Some break easier than others. If this doesn't work, try rethreading your serger from the the beginning. Upper looper first, then lower looper, then needle. Test on scraps.
12/8/2013 8:29:19 PM • White Sewing... • Answered on Dec 08, 2013
4answers
Treading my serger
When you thread the serger, your suppose to start threading the 3rd spool (left to right) first, then the 4th spool, then thread the 2nd spool which ends up in the second needle (left to right), There is a lever or bottom looper that the thread must go through before placing thread through the 2nd needle. Finally, the last spool to thread is the 1st spool (left to right). Follow the threading pattern and once you put the thread through the two loops that look like springs, turn the wheel at the right toward you until you can see like a lever with a ****, thread that **** from the back then put the thread through the machine to the right. Turn the knob to toward you again until the upper looper is showing, then you have the put your thread through the hole in that looper then through the first needle. You should now have 4 thread toward the back of your machine which you need to place under the presser foot and to the left side of the machine. There is also a VHS video that goes with the machine to help explain how to thread your serger. Also be sure that each spool of thread is in the tension of the upper colored tension wheels. If it is not, then your stitiches will be loose. Good luck and I hope this helps. I had to watch the video several times before I got it. If you don't have the video, try ebay for and perhaps you can obtain one. The video is Speedylock 1600, instructional video, USA Part #136000016, Perhaps you can contact White and see if they have one you could purchase.
Good Luck Serging!!!!
11/14/2013 6:55:16 AM • White Sewing... • Answered on Nov 14, 2013
White Sewing Speedylock 1600 Mechanical Sewing Machine Logo
159 questions posted
Top White Sewing Sewing Machines Experts
ZJ Limited
ZJ Limited
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • White Sewing Sewing Machines
Most Popular Question
white speedylock serger not staying
  • Sewing Machines
