SOURCE: My washer does not wash the clothes or go through the spin cycle.
It sound like a belt problem. Try to move tub manually first, in case it move smoothly -open the front panel, the belt should be between the motor and the drive pulley (lower front). In case it torn or not in its place, you should replace it. In case it doesn't move smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, it should be removed. Good luck !!
SOURCE: Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
SOURCE: M9503 washer dryer not draining before dry cycle.
Check these out:
SOURCE: I have a LTF2940ES1 horrible noise and wet clothes
you ahve a clogged pump
remove the toe kick
the pump will be right there on the right
get a towel and disconnect the hoses
you will see a sqaure sump take that hose off
and clean it out
check to make sure there is nothing in the pump
reassemble and should be fine
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
