20 Most Recent Amana ALW480DA Top Load Washer Questions & Answers
You're not done yet. The washer pump probably is leaking. Lots of basements being pumped out in this area as a result of the snow.
Amana ALW480DA... | Answered on Jan 16, 2018
Remove the impeller as well and see if that helps
Amana ALW480DA... | Answered on Jan 10, 2018
The drain line may be plugged into the box so tightly that air cannot escape.
Amana ALW480DA... | Answered on Apr 02, 2017
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
Amana ALW480DA... | Answered on Nov 05, 2015
PLUGGED WATER PUMP HOSE OR WATER PUMP
Amana ALW480DA... | Answered on Apr 11, 2015
Amana ALW480DA Top Load Washer Logo
205 questions posted
Top Amana Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Virgil Watts
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Washing Machines
Most Popular Question
loose agitator
  • Washing Machines
