Tank fills completely but takes too long. it filled much quicker for a long time after installation.
My sister has a two year old Jacuzzi toilet that worked fine until a few months ago. Then it started to take 10 minutes to shut off after each flush. I lifted the tank cover and immediately saw the problem; at least 90% of the refill water was going into the refill pipe instead of the tank. Upon examination I discovered that the plastic part that holds the flexible refill tube to the vertical refill pipe was broken. This part not only holds the refill tube in place, it also has a small orifice at the end to restrict the flow into the pipe. The part was broken in such a way as to let nearly all the water go into the refill pipe instead of the tank, hence it would run for 10 minutes after the toilet bowl was full and waste all that water. I found a small coarse thread stainless steel screw that fit into the plastic attachment piece to help plug the orifice and cut down the amount of water going to the refill pipe. Now the toilet flushes and refills in less than 2 minutes. I'm in the process of trying to find a replacement for that part but so far no luck.
SOURCE: Once my tank has filled (toto toilet) the fill
The fill valve isn't adjusted correctly. Does it have a ballcock or a newer fill valve? If it's the ballcock, there's a screw in the middle of the fill valve that you can loosen to lower the ballcock. If it's newer, you'll see a float that surrounds the fill valve. It has a small metal clip toward the bottom that you need to pinch to raise or lower the float. It also has a large plastic screw with a phillips head at the top for fine tuning.
SOURCE: jacuzzi toilets installed one year
sounds like you may have debris in your lines. I was not aware of this until recently but, you should drain your water heater once a year to get rid of sediments that linger and travel through your lines causing possible blockage problems. Try turning your water valve off. Flush toilet so there is no water in the toilet or tank. Unscrew your line to shut off valve to make sure there's no debris. Good Luck!
SOURCE: I have a Jacuzzi Perfecta toilet (bought Aug. 21,
Have you tried shutting water off and take top of valve appart and flush it out. It may have something in valve causing water to be restricted. It will have an arrow on it to direction to get it to come off.
Take appart and clean rubber disc and you can put something over top of valve , a small cup or something to enable you to flush the tank. Have someone help you and hold the cup above the valve so that when you turn water on for a few bursts to flush out the valve it goes into tank.
The actual stream that flows through valve is restricted down to almost 1/8 " opening so it wouldn't take mush to block the flow of water.
The disc you take out you can replace it, if it seems to be damaged and not working correctly. That will affect the flow also.
Testimonial: "I took the valve apart. It is working like it is supposed to. That sure is a tiny hole for the fill water to shoot through. that is why it is so slow. It still whistles when filling. Tnx Walter Neaves"
SOURCE: tank won't fill unless I push down on flush valve inside toilet
Hello there
ok first when the valve inside of the tank is wearing out or is dirty this will happen you can take a washrag and clean the underside of themechanism really good and also the part that it rests on providing that you can get to it
if there are no screws to adjust the water reg valve see if it will turn clockwise to shorten the arm making it turn off or if needed turn it counter clock wise i have had to also slightly bend the arm down in some units to make the water stop after the tank is full so you may want to try that too ok
hope that this helps
best regards michael
SOURCE: hissing sound in tank (fill valve)
Dear Sir,
It appears you need to adjust the float level so that it applys more pressure quickly to completely shut off the water going into the main filler tube. Does the hissing go away when you lift up on the float toward the ceiling? If it does, then you need to what I said above. Turn your float ball out farther, or carefully bend your rod down toward the base of the toilet so that it applies more pressure quickly. This should solve your issue.
Cro Dave
