20 Most Recent Kohler Cimarron Comfort Height elongated 1.6 gpf toilet with Class Six tech Questions & Answers
Is the fill line in the tank loose? Does it just shoot water into the tank itself? I had this issue until I realized the while fill tube is supposed to be pushed into the black cylinder/small plastic tube in the middle of the stopper assembly. After i pushed the line into the tube, the bowl would always only fill a little bit. Now it fills almost a 3rd of the way up the bowl and doesn't bubble during flushes.
Kohler Cimarron... | Answered on Jan 14, 2017
Kohler customer service has provided a free seal (yellow) to replace the original seal (red)on the bottom of the Aqua Piston. The yellow seal is a big improvement over the red seal, but the toilet tank still leaks. I am ready to return the toilet to Home Depot.
Kohler Cimarron... | Answered on Jun 04, 2014
There could be partial blockage of the water supply line causing a slow fill.
Kohler Cimarron... | Answered on Feb 20, 2014
Went to a Sheraton in Petaluma, CA over the weekend where they have this exact toilet that we also have two of in our home, and damn if the thing didn\'t flush there too. The maintenance guy says they have chronic problems with it.
Kohler Cimarron... | Answered on May 07, 2013
Plumbers Brisbane West : For any Plumbing Emergency please call us anytime - 0411 179 978. Your Local Plumber in Brisbane's West - On-Time - Everytime.
Kohler Cimarron... | Answered on Jun 07, 2012
Hi aselbst...
Water running is an indicator that the "Ball ****" water inlet device is leaking by, there is no fix to this problem.
You must replace the ball **** to stop the water from leaking,
The ball **** is non-repairable.
You can try to adjust the float to a lower level, sometimes that will work to stop the leak
Please take time to rate me
Kohler Cimarron... | Answered on Sep 03, 2011
how to replace a flat seal on a Kohler, Cimmaron toilet
Kohler Cimarron... | Answered on Jul 19, 2011
Try replacing the rubber flapper inside the tank.
Kohler Cimarron... | Answered on Jun 06, 2011
You just need to adjust the chain attached to the silver part. Just unhook it and go up maybe 3 links on the chain. This will help it lift up higher when you go to flush it.
Kohler Cimarron... | Answered on Apr 18, 2011
Kohler Cimarron Comfort Height elongated 1.6 gpf toilet with Class Six tech Logo
Popular Tags
53 questions posted
Top Kohler Home Experts
US Parts Center
US Parts Center
Donni Steen
john h
Are you a Kohler Home Expert? Answer questions, earn points and help others
View Most Popular
Kohler Home
  • Kohler Home
Most Popular Question
brand new elongated cimarron shoots wate
  • Home
