Sony VPL-ES7 LCD Projector Logo
olga arcos Posted on Mar 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Manual de servicio proyector sony dlp-es7 - Sony VPL-ES7 LCD Projector
Terry
Level 3:
  • Sony Master 11,377 Answers
  • Posted on Jun 27, 2018
Terry
Sony Master
Level 3:
Answers
11377
Questions
Helped
4626857
Points
152765
1 Related Answer
Anonymous
  • Posted on Aug 28, 2012
SOURCE: HOLA TENGO PROBLEMAS CON
tengo problema con mi proyector sony vpl-es4 me aparece una leyenda y me indica fuera de rango
Mitsubishi WD73838 DLP TV formatter board replacement instructions
Hi Patrick, I pass the link to the service manual of your Mitsubishi TV
I hope you can resolve your concern
Greetings Franco Dosil
Hola Patrick, te paso el link del manual de servicio de tu TV Mitsubishi
Espero puedas resolver tu inquietud
Saludos Franco Dosil
https://elektrotanya.com/mitsubishi_wd-60638_65638_73638_60738_65738_73738_82738_65838_73838_82838_60c10_65c10_73c10_chassis_v43_v43c_v43-plus_sm.pdf/download.html
I have a sony vlp vw10ht and the component red just recently seems to have faded out or stopped working. Is this a repairable situation?
Hello Dennis, please indicate, which device is connected to your Sony projector, indicate brand, model and type of device (DVD, VCR or other)
This projector has 3 Video inputs, two color inputs separately (Component Video) and one Composite video
I suggest you replace the cable between the projector and the image source and check if the problem is corrected, if you do not have another cable, try to connect some video signal to the Composite video input and see if it is missing the red color, If so, you would have a problem in the projector, if it looks good, the cable would be wrong
I hope you manage to solve the problem, comment the results
Hola Dennis, por favor indica, que aparato esta conectado a tu proyector Sony, indica marca, modelo y tipo de aparato(DVD, VCR u otro)
Este proyector tiene 3 entradas de V?deo, dos entradas de color por separado (V?deo por Componentes) y una de v?deo Compuesto
Te sugiero que reemplaces el cable entre el proyector y la fuente de imagen y compruebes si se corrige el problema, si no cuentas con otro cable, prueba conectar alguna se?al de v?deo a la entrada de V?deo compuesto y observa si esta faltando el color rojo, si es as?, tendr?as un problema en el proyector, si se ve bien, estar?a mal el cable
Espero que logres resolver el problema, comenta los resultados
https://www.projectorcentral.com/pdf/projector_manual_623.pdf
How to reset lamp timer on panasonic PT-DZ770 projector
Hello Alan, I have downloaded the user manuals in English and Spanish and in neither of the two appears the mode to reset the timer of your Panasonic PT-DZ770
I send you the Link to download and review
Question, have you tried networking the projector and controlling the functions of the projector, from a computer?
Could appear more submenu of control and adjustment
The other suggestion I make is that you call Panasonic's Customer Service, and make the query there
I hope you can solve the problem
Hola Alan, he descargado los manuales de usuario en ingles y en espa?ol y en ninguno de los dos aparece el modo para reiniciar el temporizador de tu Panasonic PT-DZ770
Te env?o los Link Para que los descargues y revises
Pregunta, has probado conectar en red al proyector y controlar las funciones del proyector, desde una computadora?
Podr?an aparecer mas submenu de control y ajuste
La otra sugerencia que te hago, es que llames al Servicio de Atenci?n al Usuario de Panasonic, y hagas la consulta ah?
espero que puedas resolver el problema
https://eww.pavc.panasonic.co.jp/projector/extranet/main/previous/dz770/manual/pt-dz770u_en.pdf
https://eww.pavc.panasonic.co.jp/projector/extranet/main/previous/dz770/manual/pt-dz770e_es.pdf
HOW DO I REMOVE THE BACK OF SONY WM-F2031 TO CHANGE THE DRIVE BELTS.
Hello Peter, in order to disarm your Sony WM-F2031, you have to follow the steps indicated in the service manual, in this in turn refers to consult the service manual of the Sony AF-23 Walkman, which uses the same cabinet
I send you the links of the two service manuals so you can disarm it and change the belts
I hope you achieve good results
Hola Peter, para poder desarmar tu Sony WM-F2031, tienes que seguir los pasos indicados en el manual de servicio, en este a su vez hace referencia a que consultes el manual de servicio del Walkman Sony AF-23, que utiliza el mismo gabinete
Te env?o los links de los dos manuales de servicio para que puedas desarmarlo y hacer el cambio de las correas
Espero que logres buenos resultados
https://freeservicemanuals.info/en/servicemanuals/download/Sony/wm-af23.pdf
https://elektrotanya.com/sony_wm-f2031.pdf/download.html
I have Sony gnv 111d system , its not working so I was using its speakers through aux(video) section & now aux is also not working Now I want to use its speakers for dish & Sony Bluray player Please can...
Hello, obviously your Sony GNV111D, does not work due to problems in the outputs or the power supply
If you have technical knowledge, I will send you the link of the service manual, if not, take it to a specialized technical service
I hope you can enjoy your Sony as soon as possible
Hola, evidentemente tu Sony GNV111D, no funciona por problemas en las salidas o la fuente de alimentacion
Si tienes conocimientos tecnicos, te envio el link del manual de servicio, sino, llevalo a un servicio tecnico especializado
Espero que puedas disfrutar de tu Sony lo antes posible
https://www.manualslib.com/products/Sony-Hcd-Gnv111d-3771741.html
1helpful
Necesito el manual de servicio para este equipo, mil gracias
¡Hola
Tengo el manual de usuario para tu Sony KDF-E42A10. Sin embargo, es un documento de Adobe Acrobat, y no puedo enviar a usted por la ventana. Es en el Idioma Ingl?s. Si desea obtener una copia de la misma, env?e su direcci?n de correo electr?nico que me ha apartado de comentarios FixYa. Voy a enviar una copia del mismo a usted por correo. Aceptar.
¡S.O.S.! necesito manual de servicio Proyector Mitsubishi XL30U
you can try mitsubishi themselves, but from experience, they don't give out anything.
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
