20 Most Recent Sony VPL-CX86 Multimedia Projector Questions & Answers
Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
Sony VPL-CX86... | Answered on Feb 26, 2015
Hello there, what has happened to your unit is an adjustment for the picture system. It has probably been adjusted from the standard mode to the dynamic mode this can be found on page 27 of the user guide. Also the directions for resetting can be found on page 26 but the problem does not have a reset function for this problem. In case you dont have the user guide here is a link to it. It also would give you directions to navigate the unit when you have constraints arising from the remote use.
Hope this support has been helpful?
Thank you for visiting FixYa.
Sony VPL-CX86... | Answered on Sep 12, 2011
hi,
for resetting lamp hour do the following
press the following keys on the remote in the following order for less than 5 seconds each.
RESET then LEFT ARROW then RIGHT ARROW then ENTER
OK,
Sony VPL-CX86... | Answered on Dec 21, 2010
Some generic solutions for WiFi dropping out may include:
1. Use of static IP addresses for the clients (in your case the 2 Sony VPL-CX86s) rather than auto obtain;
2. Disable the WEP/WPA security;
3. Set MAC filter in your router and include MAC addresses of the 2 projectors;
4. Try raising the height/position of the router; and/or
5. use an aftermarket high gain antenna for the router.
As a reminder, WiFi works by line of sight (LOS), anything in between will reduce signal strength/coverage and that include people around/near the projector unknowingly blocking the router.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Sony VPL-CX86... | Answered on Dec 12, 2007
No matter what errors are present you will need the manufacturer to repair it, they do not supply repair info or parts to the public, only approved repair stations.
Sony Office... | Answered on Aug 21, 2019
Sony vpl-es 5
How to unlock
Without remot
Sony Office... | Answered on Jul 10, 2019
how many times of the power indicator light
just like 2 times ,3 times ,5times...
Please tell me more details
I am an expert of repairing projectors for 19 years.
It is my pleasure to receive the message form you,
WhatsApp ID:+8613178867858
Skype:lampdeng@hotmail.com
Wechat ID:+8613178867858
Email:jerry@lampdeng.com
Email:lampdeng@hotmail.com
Mobile:+86 13178867858
http://www.lampdeng.com
Sony Office... | Answered on May 31, 2019
The power indicator is off.
two reason:
1,the mainboard is fault
2,the powersupply is fault
reason:
1,check the cover of the lamp,
there is a siwtch under the cover of the lamp
make sure the switch is on the right place
2,air film,
there is a siwtch under the air film
2 times
reason:
2,air film,
Sony VPL-CX86 Multimedia Projector Logo
Popular Tags
19 questions posted
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
jasbo
jasbo
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Office Equipment & Supplies
Most Popular Question
need reset lamp replaced lamp installed
  • Office Equipment & Supplies
