Xerox DocuColor 12 Color Copier Logo
Posted on Oct 15, 2008
Eror code 3-380 System Fault problem
Whenever switchon my Dc12 The mahinc ready within 5 minutes and final stage it shows the eror like "System Fault" error code 3 -380 Switch of your printer and on. How can I solve it.
  • 2 more comments
  • Anonymous Mar 12, 2009
  • carlosdiaz77 Apr 04, 2009
    My fiery unit error is about the loading message at screen but it´s keeping loading and does not anything else.
  • Anonymous Mar 20, 2014
    Dell 1355cm printer - not working. Shows error code 009-654 2880000 how can I ascertain what the error defines and more importantly, how can I fix it
  • Anonymous Mar 21, 2014
    error code 6202 switched on & off still shows eror code esp 3.2 printer
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 18, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1733
Points
7
Anonymous
Level 1:
  • Posted on Mar 26, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1460
Points
8
I change the IBT BELT and fix the problem
1helpful
Dryer chirping along with the following: start button flashing, dry temp on high light lit, 56 on timer timed dry lit and dry time selector lit was on sensor dry when we left and turned off
Disconnect power or turn breaker off for about 5 minutes. This may reset the unit. Otherwise you have an eror showing and need to retrieve the error code. Google your make and model followed by error codes a d you should get a link to retrieve the codes.
How can I reset eror code CO 500 on konica minolta copier DI 2510
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
1helpful
2answers
WHAT IS THE MEANING OF FAULT CODE 21,24 AND 31
21 - VANOS solenoid activation, intake Output digital pulse width (active low)
DME final stage will set flag
whenever a short to ground, a short
to battery voltage or a disconnection
between output transistor and
component exists.
24 - Injector circuit cyl. 4 Output digital pulse width (active low)
component exists.
31 - Ignition coil cyl.5 Input analog timing
DME initiates secondary ignition for
(100 mV) each cylinder then looks for feedback
through shunt resistor in harness to
determine if ignition actually occurred.
2answers
Colour Xerox Machine problem
its a problem with the fuser unit ,its overheating .two ways to solve it first check if the sticker paper is supported by your printer ,2nd you may need to replace the fuser unit
Eror f2
F2~37 is a Drum Process Control error, if it does not clear with a couple of power-up cycles...then the only thing you can do is wait for a suitably qualified Engineer to fault check the Drum unit and sensors.
Just trying to clear the error code within maintenance program will not solve anything until the root cause has been found as this code will repeat and continue to stop the machine until it is dealt with.
Lucas
2helpful
2answers
Eror sc 500
remove all paper from the trays then turn machine off wait a few second then turn back on should reset then reload paper
Zoom eror
Yes we have solved the problem. You'll need to enroll with our "Bhola Special Offer Package" for $500 to know how we did it.
Thanks,
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
