20 Most Recent Xerox CopyCentre C128 Black and White Copier Questions & Answers
It's a fault relate with IP address. There is a PC which take the IP of Printer. Find this PC and turn off it in moment just restart Printer before restart PC
Xerox CopyCentre... | Answered on Aug 25, 2019
There is a loose connection on the finisher. The fault code does not appear if the copy/print is delivered to the middle tray I think.
The code means that the "offset catch tray home sensor did not turn on in specified time". You may manually move the offset mechanism and see if it moves smoothly.
Xerox CopyCentre... | Answered on Oct 12, 2018
A PC with the same IP address exists on the network.
arrwup.gif Procedure Inform the customer that the IP address of the machine is the same as the IP address of another machine on the network.
Xerox CopyCentre... | Answered on Nov 21, 2017
What is the solution to solve Error code 027 452
Xerox CopyCentre... | Answered on Oct 18, 2016
machine show error code of 010-327. how to correct this error
Xerox CopyCentre... | Answered on Jul 07, 2015
reset ur fuser module
press 0 and hold for 5 second than press start button
enter passcode 6789 and press confirm
press machine status and press tools on touch screen
press maintenance and diagnostics
nvm read /write
type chainlink 744-220
enter new value 0 and save
after close the log
restart ur machine
Xerox CopyCentre... | Answered on Dec 06, 2014
Platen AOC Failure.
Power off completely and then power back on.
If the problem persists please Call for Service.
Xerox CopyCentre... | Answered on Jul 14, 2014
there is a toner counter chip for 128 .check if u have replaced with new one that it might have been out of position.if possible call a rep as it is a bit tricky
Xerox CopyCentre... | Answered on Sep 15, 2011
U HAVE TO CHANGE THE DRUM CARTRIDGE OR IF UR A SERVICE REP U CAN ALSO CHANGE THE CHIP TO MAKE IT WORK
Xerox CopyCentre... | Answered on Aug 02, 2011
Xerox CopyCentre C128 Black and White Copier Logo
52 questions posted
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Xerox Office Equipment & Supplies
Most Popular Question
fault code 047 211
  • Office Equipment & Supplies
