20 Most Recent
Fuji FinePix S5700 Digital Camera Questions & Answers
No view from screen or viewfinder
Hi, have you tried another memory card in case the other one is faulty ,if the original card is ok then you will have to put into a fuji repairer to inspect. If you are still under guarantee the contact fujifilm.
How do I download pictures from Finepix S5700 to PC with Windows 8.1?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
My computer will not download pictures from my s5700 camera
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as the Finepix viewer or Picasa (
Transfer pc
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Hello, I purchased a finepix s5700 about 18 months
Your
problem
may be due to weak/worn out batteries or corrosion on the battery
contacts inside the camera which can
prevent the full power of the batteries from flowing into the camera.
Try this free fix before you do anything else: remove the batteries and
wipe the camera contacts firmly with
a dry cloth (heavy corrosion may require cleaning with a wire brush,
steel wool, or sandpaper). Remove any residue that may have fallen into
the battery compartment during cleaning, then wipe both ends of
the batteries and place them back in the camera and give them a full
charge (assuming that you are using rechargeable batteries
). This
cleaning clears
the problem about 90% of the time. If it doesn't work for you, it may be time for new batteries, or the
camera may have
a problem that requires professional repair.
Software mac onto usb
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo management program.
I have a finepix s fuji camera and a mini apple mac and i cannot download the pickies onto my computor!
Reset language change
Press the MENU/OK button. Select the wrench-2 icon. Select the first icon (the talking-head).
How can I transfer my
I don't know if there is a function to do this on your camera, but on the cameras I am familiar with, there is not.
However, if what you want to accomplish is to get your pictures from internal memory into your computer, there is a way. Simply remove the memory card from your camera before connecting the camera to your computer. The computer will then see the camera's internal memory instead of the card memory, and you can copy the pictures over.
If you have been accessing your pictures by removing the card from the camera and placing it in a card reader attached to your computer, then this won't work for pictures in the internal memory. You will need to use the other method, connecting the camera to the computer with the USB lead.
Fujifilm memory full
Try formatting the memory using the camera. Open the camera's Menu scroll through the settings to Format memory.
