20 Most Recent Xerox WorkCentre 7328 Multifunction laser printer Questions & Answers
016-799 Wrong combination of print parameters, like selecting to print on custom size paper and setting [Auto] for [Paper Source] on the printer driver and [Auto] for [Paper Size] in trays 1 to 4 on the control panel.
Check the print parameters.What we did is match the documents page size and paper type to the printers (A4) then we could print.
Xerox WorkCentre... | Answered on Jul 11, 2019
I don't have that manual, but similar manuals say IBT Home Sensor Error. Check your accumulator belt for damage. You may also have a dirty sensor.
The belt PN is 604K20891and is rather expensive and fragile
Whit
Item, Inc.
Xerox WorkCentre... | Answered on May 20, 2019
I face an Error code problame 004-350 please told the relief of this code
Xerox WorkCentre... | Answered on Jul 03, 2018
Hi
Xerox Werk Centre 7428 Tray 2 NVM Read / Write Chain-Linc & Current Value
Xerox WorkCentre... | Answered on May 21, 2018
from what I found here
Thread workcentre 7345 error code 009 349
It looks as if you will need a technician to service it
Xerox WorkCentre... | Answered on Jul 07, 2017
Xerox 7346
What is the problem of error code 008-164
Xerox WorkCentre... | Answered on Aug 09, 2016
reopen the cover and look inside with a flash light, there maybe a tiny piece of paper stuck in there you missed, take some compressed air and blow it in there to clean out dust, the talcum powder on the paper, builds up on the sensors, making them think it has paper there.
Xerox WorkCentre... | Answered on Oct 08, 2015
There's no reset for that error, the error indicates that the 1st BTR did not reach the retract position. Try clean the 1st BTR Retract Sensor and look for damage. Also check the gears for breakage.
Xerox WorkCentre... | Answered on Aug 11, 2015
Try : eBay.com
Just make sure you search by part number not machine model number.
eBayeBay
Xerox WorkCentre... | Answered on Jul 07, 2015
Changing the Toner Cartridge sensor is not an easy task.
However if you want to start playing with the internals, firstly you would need to remove external panels.
some sensors look the same and are not interchangeable, but the ones that are, would be easy to spot. If you have a faulty cartridge sensor it would be interchangeable with the others.
Try it, and see what the response you get.
a Xerox service might pay you dividends.
Good luck.
Xerox WorkCentre... | Answered on Apr 02, 2015
The error means that the interval of the ROS (C) signals exceeds the specified value. The normal problem is a bad mcu board. Measure the value between PJ401 on the MCU board and and ground for +5vdc. If you get +5 then replace the MCU board. Part number 960k31352. http://www.iteminconline.com/itemdesc.asp?ic=960K31355&eq=&Tp=
Xerox WorkCentre... | Answered on Sep 26, 2014
116-314 is an ethernet address error. Can you ping the network port? Try reseat the eeprom on the main board. If the settings are all correct and none of that works, you will have to replace the main board, part number 960K39010.
http://www.iteminconline.com/itemdesc.asp?ic=960K39010&eq=&Tp=
I share a links, so read it and follow instructions. If not understand then contact printer support technician and check it why your printer touch screen not working.
Read more..http://www.office.xerox.com/latest/W73EG-01U.pdfand Xerox Printer Support
Thanks,
Xerox WorkCentre... | Answered on Sep 05, 2014
Xerox WorkCentre 7328 Multifunction laser printer Logo
97 questions posted
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Xerox Office Equipment & Supplies
Most Popular Question
009 349 key reset
  • Office Equipment & Supplies
