The workings of a bath jet...From the inside of the Bath there is a wall fitting that threads from the inside of the tub into the jet body located on the outside wall of the tub.
If the jet is leaking at this point behind the tub then you should take the wall fitting out of the tub and put a small bead of 100% RTV silicone around the flange of the wall fitting and reinstall it.
If however, the leak is from the PVC piping going into the jet then you will need to replace the jet.
Rod
US Parts Center888-521-6183
