20 Most Recent
Jacuzzi Signa 6 Whirlpool JAC-B540... Questions & Answers
Faucet placement on Jacuzzi 6036
If there is room most definitely you can place the faucets on the tub itself. You can mount them on the left rear. However be very careful drilling the holes and make sure you have it aligned correctly before drilling. Check underneath to make sure there is enough room for clearance and hook up. Here is what it will look like.
Two person jacuzzi that hasn;t been used for several years. Iron
You are on the right track. Be sure and chlorinate and run the jets at the same time I would let it set for at least a couple of hours running the jet intermittantly and then drain and repeat.
Sound like you have Iron Bacteria. You may want ot contact a water profeessional who can recommend ways of getting rid of the iron.
Properly Chlorinating your well would be a good first step.
What part of the country are you in>
sanray
Trash come out of jets
Sounds like the hoses to the jets are the pump are breaking down and pieces coming off. Replace the bad hoze(s).
Water not coming out properly from one of the jets
hi there. FIrst of all be sure the water lever is above all of the jets for it to work properly. REgarding the jet where the water does not come out properly i am not sure what that means. BUT, the jet is adjustable so turn it and see if that fixes the problem. good luck.
Jacuzzi bath
Many time leaks around pumps are a simple o-ring that needs to be cleaned and/or tightened. If the jets are leaking from the back side then the jet will have to be removed and resealed.
Good Luck, Phil
The on off light in my Jacuzzi whirlpool bath keeps flashing
The flashing on/off light in a Jacuzzi whirlpool bath may indicate an issue with the control system, and it's important to address the problem to ensure the proper functioning and safety of the whirlpool bath. Here are some general steps you can take to troubleshoot the issue:
1. Check the Power Supply:
- Ensure that the whirlpool bath is receiving power. Verify that the circuit breaker for the whirlpool bath is not tripped, and check for any loose or disconnected power cords.
2. Inspect the Control Panel:
- Examine the control panel for any visible issues, such as loose or damaged wires, connectors, or buttons. Ensure that there is no water or moisture present in the control panel area.
3. Reset the System:
- Some whirlpool baths have a reset function. Turn off the power to the unit, wait for a few minutes, and then turn it back on. This can sometimes reset the control system.
4. Refer to the User Manual:
- Check the user manual that came with your Jacuzzi whirlpool bath for specific information on troubleshooting and resetting the control system. The manual may provide insights into the meaning of the flashing light and how to address it.
5. Contact Jacuzzi Customer Support:
- If the issue persists and you cannot find a resolution through the manual, contact Jacuzzi customer support or the manufacturer for assistance. They may be able to provide guidance on how to troubleshoot and resolve the issue.
6. Professional Inspection:
- If you're not comfortable or able to identify and fix the issue, it's advisable to seek assistance from a qualified professional or a technician experienced in Jacuzzi whirlpool bath systems. They can perform a thorough inspection and diagnose and repair any electrical or control system problems.
It's essential to prioritize safety and follow proper procedures when dealing with electrical components and water. If you're uncertain or if the troubleshooting steps don't resolve the issue, it's best to seek professional assistance to avoid potential hazards.
12/17/2023 11:37:18 AM •
Jacuzzi Home
Answered
on Dec 17, 2023
My Jacuzzi bathtub won't start-188 error code
Please attempt to start the jacuzzi without any water and see if it functions. Then you can fill the jacuzzi up to 1/4th with water and check if it continues to run. If so, continue to one half full. If this jacuzzi breaks down at these water levels, then you'd need to call the manufacturer to advise on what part needs to be changed to get everything working again. Thank you.
8/21/2022 9:40:54 AM •
Jacuzzi Home
Answered
on Aug 21, 2022
