Hi Richard,
Please follow the steps below to make sure that the carriage can move freely and is properly seated. Check the carriage path. Press the Power button to turn the product on, if it is not already on. Open the cartridge access door. The carriage might try to move into the access area at the right. Allow the carriage to move to that position.
1. Open the cartridge door.
2. Wait until the carriage is idle and silent.
3. Without turning off the product, disconnect the power cord from the rear of the product.
WARNING: In the following steps, you move parts by hand. You must disconnect the power cord from the rear of the product to eliminate the risk of an electrical shock and to reset the paper-feed mechanism.
4. Disconnect the power cord from the wall outlet or power strip.
5. Look inside the product to see where the carriage is stuck, and then check for any torn paper or other objects that might restrict the carriage.
NOTE: You might need a flashlight to illuminate areas for proper viewing.
6. Remove any loose paper or obstructions found.
7. Reach inside the product through the cartridge door, and then manually move the carriage.
8. If the carriage is stuck on the right side of the product , move the carriage to the left side of the product.
9. If the carriage is stuck on the left side of the product , move the carriage to the right side of the product.
10. If the carriage is stuck in the middle of the product , move the carriage to the right side of the product.
11. Make sure the carriage moves freely across the width of the product. Firmly push the carriage to the left side of the product, and then to the right side.
12. Close the cartridge accei have an hp c 3180. Changed the black ink - c00652944.gife the cartridge access door
13. Reconnect the power cord to the rear of the product.
14. Plug the power cord into the wall outlet or power strip.
15. Press the Power button to turn on the product.
Hope it helps.
Thank you for using FixYa.
It is stuck to the left. How do I get it to move... i can't grab it
I have, as noted, an HP C 3180. The carriage is stuck to the far left, so that I can't grab it. Please identify what you would suggest... the front is open so that I can see the carriage, i just can't grab it.
There seems to be a problem with the cradle not "lifting" itself up and over what appears to be some sort of guide. Open the cartridge access and unplug the power. Try pushing the carriage to the far right but don't force it if you find resistance. Rock the cradle gently back by hand (it will only move a few millimeters) and move it all the way to the right into its bay. Cycle the printer power and it should be fine. If it will not go into the service station (SS) area on the right, I would recommend to service the product to prevent further damage on the unit. They will have to do some disassembly to check the carriage drive motor and main electronic board.
Hope it helps.
SOURCE: hp 3180 print cartridge light blinking
hi,
is the ink cartridge you replaced hp brand or did you refill it this is an incompatibility code from the software. some brands and cartridges are not fully compatible and creates an e code error code. if it is hp brand it is likely a defective sensor chip in the ink cartridge. i would for best assurance return the cartridge for a different one and then recheck. if niot you may need to restore your software or reinstall it most of the time this will fix the problem.
hope this helps..happy computing!
SOURCE: Cartridge is stuck in the wrong carriage...
only thin you can do is unforced the ink cart out
SOURCE: black ink cartidge
If a black cartridge will not print, with no error messages, it is probably th printhead. Clean it with proper cleaning solution. Refilled ones if done yourself or by someone else, can also have air bubbles, Try blowing down refill hole with tissue under the cartridge to stop ink spills. Also, if you press a folder non scented wipe under the cartridge firmly, you should get a solid little black line or impression. This will tell you if the ink is getting down ok. Try reprinting.
SOURCE: HP Deskjet 5550 cartridge carriage stuck SPAM SPAM SPAM 1-800-532-4187
I have had this happen. The easy way to fix, is put a ***** driver, or similar, down to the blue clip and press down. whilst doing this gently pull the holder back. it seems to happen if you dont close the blue clip correctly.
SOURCE: carriage jam
if u r a professional, mind for service..look for loose carriage belt or faulty drive assembly..oil/grease n check all the gears..
hope it'll solve problem..
always better to hv supervision of system admin/vendor....
