Model number-fef336ece
Hello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor or a bad door latch switch mechanism or a bad control board. To solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement as then it seems that the door switch is also fine. Please get back to me if you have any other questions.
Kevin
