I have messed up the spools in back of machine due to moving. Is there a ways to get an image so I canput them in the correct places to thread. I cannot figure it out.The manual does NOT show diagram.
Appreciate your help. mail image to [email protected]
It shows in the beginning pages of the manual how to assemble the machine.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwjHoOWmm8TYAhXDw1QKHfu9DiAQFggnMAA&url=http%3A%2F%2Fjanome.com%2Fsiteassets%2Fsupport%2Fmanuals%2Fsergers%2Finst-book-634d.pdf&usg=AOvVaw2nMzrZhmnL1imJDHhkHGJZ
SOURCE: Problem with spool Thread, please suggest a solution!
This is a tension problem.
In addition to the top thread having a tension adjustment there is the facility to adjust the tension of the bottom(bobbin) thread.
Both these tensions need to be correct to get a balanced stitch and to stop the loose threads underneath the cloth.
It is almost impossible to explain how to adjust the bottom tension you need to be shown.
Somewhere in your manual it should explain how to do this.
SOURCE: How to thread thread
Here's the Janome instructions!
http://janome.com/index.cfm/LearningCenter/Techniques/General/Winding_A_Bobbin
SOURCE: I need instructions to Thread a White Super Lock 534 Serger
I hope this helps. there a lot of other vidios you can try as well. DFD
SOURCE: WHERE CAN I FIND MANUALS FOR JANOME SEWING
Look HERE for Janome User Manuals, enter model number in the search box (top left). Janome Service & Repair Manuals HERE just request your model.
SOURCE: Correct placement of overlocker needle.
can,t do you a diagram, but the needle has a scoop out on one side this should face toward the looper that picks up the thread
Testimonial: "thank you so much this info was really great."
