Graininess can be caused by a high ISO setting while taking pictures in low light situations. You could also have the picture quality set to a low megapixel setting.
This is not an answer. The S3 normally does not produce dark pictures, and I have seen this issue before. It has to do with a setting somewhere on that camera that needs to be adjusted. I wish I knew what that setting was/is as my wife's camera has recently started doing this ...
Some people report that with an ISO setting of 200 or higher, there is graininess in the pictures, so check your ISO setting. I don't own one of these cameras, but there is a lot of discussion on the net about them. The following amazon discussion about the problem deals with a fellow who upgraded to the S3 from the S1. One problem was the ISO setting got bumped up, but another problem was the ISO was increased in the Sports Mode. See if any of this applies to your situations: http://www.amazon.com/Grainy-noisy-pixelated-photos/forum/Fx36DLASC37633N/Tx2BFEA8BW518TA/1?_encoding=UTF8&asin=B000EMWBV0
You need to check your ISO setting and the picture quality you have your camera set to. It should be at the maximum megapixels and fine quality and the ISO should be below 800 or even 400.
The Canon A95 has been known for taking noisy and grainy photos. Try using a low ISO setting of 50 or 100 to see if that helps. Using auto ISO or ISO above 100 will put more noise/grain in your photos. Also, always shoot in the best lighting situation possible. The more light the better. You can always improve your photos with good editing software too.
I hope this helps and good luck!
When using sport mode the ISO jumps to 400 or more, and this is very noticeable in the grain of the picture. S3 renders good detail up to ISO 200. My advice: Set ISO to 200 in Tv mode, then set the shutter speed to 400 or something like that using the < > buttons. You have to try the best speed under the light you are. If the light is very good, perhaps you can use ISO 100 and get much better results.
The reason for this is that the auto scene function chooses which ISO (light sensitivity) is needed to have a fast enough shutter speed to capture a still image (instead of a ghosted image). There is no way to change this. You can switch modes to P and specify the ISO you want to use (100-200 will give you a clear, non-grainy image, 400+ will be grainy). To capture a still image in low light with a low ISO, you need to use a tripod. Hope this helps.
grainy pictures are possibly casued by a very high ISO (sensativity) setting, you should be on 100 or lower for best normal shots. Higher settings are for low light and custom shooting in strange lighting or aperature/shutter speeds. Try full auto setting.
