20 Most Recent Canon PowerShot A95 Digital Camera Questions & Answers
I have a Canon Powershot A95. The lens won't come
press the "display" button while in picture mode, it should make normal.
7/11/2019 4:08:57 PM • Canon PowerShot... • Answered on Jul 11, 2019
2answers
When focus the image is not clear
Focus on the nearest edges.. that will give you a "beep" sound which confirms the focus is established. You may need to turn the "beep" sound on from the settings. Hope it helps. Cheers !
11/4/2018 9:08:29 AM • Canon PowerShot... • Answered on Nov 04, 2018
2answers
My camera, a brand new
If, as you indicate, brand new return for exchange or have it repaired under Canon warranty.
9/14/2017 11:06:32 AM • Canon PowerShot... • Answered on Sep 14, 2017
Canon A95 "Change Batteries" problem!
You need to use 2100 mAH or 2300 mAh rechargeable batteries - alkaline batteries will not maintain the high level of power required.
8/6/2017 10:05:39 AM • Canon PowerShot... • Answered on Aug 06, 2017
No pictures found on pc
Easiest way is to put the media card into a USB card reader attached to the computer.
4/19/2017 7:31:15 PM • Canon PowerShot... • Answered on Apr 19, 2017
My Canon Power Shot A95 clicks when turned on.....what do i do?
The lens is trying to extend you may need someone to repair it.
11/2/2016 8:15:20 PM • Canon PowerShot... • Answered on Nov 02, 2016
Overcharged batteries used in A95. I put new Li ion batteries in my canon A95. Camera would not work after I did this. I took the batteries and tried checking them in a flashlight. When I turned the f
Lin, I'm afraid you are right. The camera should work on 4 AA Alkaline or NiMH rechargeable batteries. They give about 1,5 V maximal. The Li iOn batteries, almost deliver 2 V each. 4 x 1,5 (6) or 4 x 2 (8) gives a difference of 2 V. that is almost 33% to much. But before you panic, Please first check if the contacts in the camera are clean and shiny. You can clean them (if necessary) with a dry cloth or cotton swab. Don't use anything sharp in or close to a camera. Then insert new alkaline or NiMH barrettes, as shown in the manual and switch it on. If it still does not work, contact a Canon certified repair centre and tell them what you did with the batteries and ask them if the camera is worth repairing. Success
11/3/2014 7:59:40 PM • Canon PowerShot... • Answered on Nov 03, 2014
2answers
How can i transfer pictures to windows 8.1
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
8/1/2014 9:10:59 PM • Canon PowerShot... • Answered on Aug 01, 2014
0answers
Canon A 95 Digital Camera Set up instructions
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a95#BrochuresAndManuals
6/29/2014 6:49:50 PM • Canon PowerShot... • Answered on Jun 29, 2014
Power wont turn on
Hi, If the camera will not power up then please check the following: 1. That the batteries are inserted correctly. Two should be facing upwards and two downwards. With the camera facing you (upside down) then the first battery on the left should have the positive terminal up, the second down, third up and last one down. If this does not work then ensure the slider switch to close the battery cover is fully closed - sometimes this sticks - as this closes a microswitch. If the camera still does not work then a fuse will have blown in the camera. This would be a very expensive repair. Hope this helps
5/23/2014 3:26:43 PM • Canon PowerShot... • Answered on May 23, 2014
Only settings display on lcd no image
Hi, This will either be the setting on the DISP button (back of camera) or a failure of the CCD (image processor). If the pressing of the DISP button does not restore the picture then it will be a CCD failure. The CCD failure was a common fault with the Canon A cameras and Canon repaired these free of charge up until a couple of years ago. This can be replaced by a Canon repair centre, however it will be costly. Hope this helps.
5/23/2014 3:21:17 PM • Canon PowerShot... • Answered on May 23, 2014
Canon PowerShot A95 Digital Camera Logo
642 questions posted
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
overcharged batteries used in a95 put
  • Cameras
