20 Most Recent Karcher K2.26 Electric Power Washer Questions & Answers
Had the same problem and it turned out to be an obstruction in the nozzle and I mean a small obstruction, it looked like an ant leg. I pushed a 1mm drill bit through and now it works fine.
Karcher K2.26... | Answered on Apr 07, 2019
looks like there are a couple of screws thru it
Karcher K2.26... | Answered on Sep 21, 2016
up end the unit and get to the sump plate of the pump
remove the big screws that hold it on and there is a big"O" ring that is the seal
replace that "O" ring and use silastic blue sealer and reassemble it
Karcher K2.26... | Answered on Jun 01, 2016
If the unit has seen a few tens of hours of work, it may be the brushes. My unit was going fine, then for a minute or 2, it was like someone was winding the inlet power down then back up. Then it stopped and would not start. I replaced the brushes and it now runs as it did. Several 10's of hours old, but not ready for the scrap pile yet.
Karcher K2.26... | Answered on Mar 07, 2016
www.pressure-washer-parts.com has many parts available. There are complete guns, and gun repair parts listed here.
Karcher K2.26... | Answered on Aug 09, 2015
You should watch the video on this blog. This is a very common problem, because the original gun/wand on many pressure washers is the same! However, Prism Teachings observed something that you should know about its design: http://electricreplacementgun.blogspot.com/
Karcher K2.26... | Answered on Apr 17, 2015
the seal in the plunger valve of your wand is bad or possibly it froze and cracked...either way to work on it far exceeds the cost of a new one so you will just save yourself time and money by buying a new wand at a local dealership...good luck
Karcher K2.26... | Answered on Feb 26, 2015
If it is popping off from machine side, the outlet thread could be damaged. This both on the machine and on the hose.
If it is popping out at the gun end, there must be a clip that holds it in place missing. This I am assuming that you have the right hose for the right machine. Using hoses not intended, will cause a lot of problems. Even actual hoses, they never should be modified.
Regards.
MG.
Karcher K2.26... | Answered on Feb 20, 2015
Peter , sorry to say but there is no replacement parts for that lance , you just replace the entire thing
its called a Dirtblaster lance
Karcher K2.26... | Answered on Nov 29, 2014
Run a search on the internet; usually they pop up.
Karcher K2.26... | Answered on Nov 26, 2014
This is could be the capacitor that has failed. The capacitor gives the motor the initial kick in the right direction to get it started. You can confirm it is a failed capacitor and that the motor is still ok by flicking the fan blades with a stick in the direction it should spin just as you switch the pump on. The pump should run normally. You can get them off Amazon or ebay for around 5 Pounds (GBP)
Karcher K2.26... | Answered on Oct 14, 2014
This could be because the motor/pump has seized. It is also possible that there has been insulation or waterproofing has broken down.
Stop using the machine and take to a service center.
Karcher K2.26... | Answered on Sep 26, 2014
check your lance nozzle is not blocked... Remove the lance from the trigger assy and see if you have water coming through then. If you do then the nozzle is blocked :@)
Karcher K2.26... | Answered on Jul 22, 2014
Yes, the on off switch is probably bad, go to karcher.com for parts and schematics.
Karcher K2.26... | Answered on Jul 20, 2014
Karcher K2.26 Electric Power Washer Logo
358 questions posted
Top Karcher Garden Experts
John Trevino
Ian Summerfield
Ian Summerfield
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
View Most Popular
Karcher Garden
  • Karcher Garden
Most Popular Question
karcher dirtblaster jet not rotate
  • Garden
