20 Most Recent
Karcher PSI Electric Pressure Washer Questions & Answers
Karcher pressure washer
most likely motor or pump overheated and seized or burnt out remove cover to the unit and test for motor operation
I am looking for a workshop manual for karcher hds
hi could you post your email address and i can email you a full pdf file, also on the chassis of the machine there will be a silver sticker could do with all the numbers to find which modle it is regards
I have a Kew Hobby 80. The output from the lance
Could be the input water pressure is not sufficient. There is a pressure valve inside the machine that will cut off the motor if input pressure is too low or non existent.
Try a different source for the water input.
Water leaks from trigger wand replaced o ring
Dear Robertkoch,
These type of wands are throw away type. The water could be leaking from the hose with the wand. It could be leaking from the valve. That is the valve is not closing when trigger is not pulled. Myself even when a wand (gun) is serviceable...I do not find it worth it fixing it. The wise thing to do is buy a new one. But if you wish to experiment and drill the rivets...and by any chance you fix the problem...then good luck for you. If you decide to buy a new wand...buy exactly the same as you have, so maybe you might use a spare from the old one for the new one when the time arrises.
Regards,
Fulltech.
Used 2 hours now nothing checked all fuses.
Check the power cord from the end where you plug it in all the way to where it wires into the switch and check the switch also! They are notorious for going out! Best of luck!
I have a karcher pressure
you will have to take the cover off & look for melted wires or a fuse.
if there is no fuse the capacitor may have been cooked.
it should be a white cylinder.if it has been damaged it will have burn marks and may be swollen.
replace the capacitor and it should start.
Kacher machine K2.98
So when you are using the machine & keeping the trigger pulled open the machine builds up to pressure then knocks off all the time.
If this is so the machine is not at fault & is doing what it is meant to do & protect its self from over pressuring & the fault is in the nozzles you are using.
You need to check the nozzle size is correct for the machine & also airline the nozzle to clear of any dirt.
Thanks qwashers
