20 Most Recent Karcher G3025OH Pressure Washer Questions & Answers
the wand is probably plugged with spiderwebs .
Karcher G3025OH... | Answered on Oct 13, 2015
why are they useless?thats usually the only thing that goes wrong.unless youve split the pipe,or the trigger o ring is leaking.
Karcher G3025OH... | Answered on Apr 21, 2015
Varies. Check manual or go to web site.
Karcher G3025OH... | Answered on Oct 13, 2014
remove bolts replace cord housing
intall bolts.
Karcher G3025OH... | Answered on May 15, 2014
It sounds more like a carb problem flooding and dumping some gas into the oil. This unit probably has a low oil sensor and the gas could be affecting this. I would have somebody look at the carb and find out why doing this, change the oil and try again. I have one that leaks gas because of float problems, that has done it since new, waiting for spring to remedy. Good luck, Also you can go to Karcher.com for a parts explosion and manual if needed.
Karcher G3025OH... | Answered on Nov 16, 2013
check for possible excessive fuel and or oil in intake by removing air filter and looking in the throat of carburetor.
Karcher G3025OH... | Answered on Aug 04, 2013
Did you turn the choke off after starting unit
Karcher G3025OH... | Answered on May 25, 2013
I would first try draining the carb bowl, if you look at where the choke lever is and look below that you should see a clear red tube with a flat head screw below that, if you just turn the screw out the carb will drain. If you still have an issue you are going to have to clean the carb.
Karcher G3025OH... | Answered on Jul 21, 2012
Did you try pulling the spark plug and spraying some starter fluid or carb cleaner into the cylinder, putting the spark plug back in and starting it? If you've got spark and it doesn't start for a few seconds then you probably have carb problems. Good luck!
Karcher G3025OH... | Answered on Jun 19, 2012
Hi ruthkapres:
Here is a diagram. The unloader/spill valve is #12 on page D2 or F2 depending on your model. You must pull it out, inspect the o-rings for dents or tears and make sure the valve is lubricated with a good water proof lubricant.
Karcher G3025OH... | Answered on Apr 05, 2012
Karcher G3025OH Pressure Washer Logo
92 questions posted
Top Karcher Garden Experts
John Trevino
Ian Summerfield
Ian Summerfield
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
View Most Popular
Karcher Garden
  • Karcher Garden
Most Popular Question
pressure washer started smoking shut off
  • Garden
