20 Most Recent Karcher G 2600 VH Gas Pressure Washer Questions & Answers
I will take a shot at this question, only because I had a similar problem this past spring. You probably have everything hooked up correctly, the pump, the shaft key, and everything else the way it should be. If the unit sat for a while, or a long period of time ,it may have built up some rust , at the nozzle end. I will assume that your pump comes on and no water comes out of nozzle. If this is so remove nozzle and look through the small hole in nozzle. If you don't see light this is most likely your problem. Take a small piece of wire, or a pin and push it through. I had a nozzle clog on me this way. I didn't think this could happen till I started to diagnose down the line. Please get back to me with your results. GOOD LUCK FREIND.
Karcher G 2600... | Answered on Oct 06, 2014
For item 5, I would check the Detergent Injector, water should never come out there, Maybe something (dirt) is causing it to malfunction.
see picture here http://www.ereplacementparts.com/spare-parts-kit-p-482334.html. Check the ball, o-ring and spring... leakage like this would be one reason for no pressure, It's like not having a nozzle on. fix the leak at the quick connect as well, check the o-ring and replace of it is hard and brittle or nicked. tighten the connection if it is leaking at the threads, some thread sealer sutiable for 2600PSI maybe.
Engine surging problem 'may' go away once you get a proper load on it...
If this is a new pump contact the supplier, maybe it is defective.
Karcher G 2600... | Answered on Sep 10, 2014
you mean water in the pump oil ??? or engine oil ???
im suspecting pump oil... you didn\'t seal it properly or you have a crack somewhere in the main housing. rarely is it viable to repair these pumps... if you search a little you can find replacements pretty damn cheap !!!
Karcher G 2600... | Answered on Aug 29, 2014
I have same model with same problem. Tried the easy fixes:
unloader valve lube and clean, inlet water sufficient, and nozzles and hose are fine. Broke down pump and called for parts (about $50 for 3 inlet valves and some seals) hopefully this will fix it. Mine has been used in my business pretty hard for a few years, so not bad.
Joebro
Karcher G 2600... | Answered on Aug 16, 2014
suspect water in oil... just change the oil and see if it returns. it's very rare that a pressure pump can get water into the engine
Karcher G 2600... | Answered on Nov 27, 2013
either the checkvalves closed on the inlet or the chemical injector on the output may be clogged they will have to be removed for inspection.
Karcher G 2600... | Answered on Aug 05, 2013
I assume you are talking about the pump. Not good, remove
pump, disassemble and oil falls out. Put in new oil upside down
and reassemble pump, then reinstall.
Karcher G 2600... | Answered on Apr 29, 2013
.This is in answer to no soap on the Karcher Factory-Reconditioned 2,600 PSI 2.3 GPM Gas Pressure Washer G 2600 VHR
Use the 65 degree low pressure nozzle for soap. The nozzle is black.
I missed it in the manual..drove me nuts until I slowed down to recheck the manual..
Karcher G 2600... | Answered on Apr 19, 2013
You need to expel all of the air that has ran through the supply hose and into the pump. Do this without the machine running. Squeeze the trigger and let the water run through the machine for 30 seconds or until all the air has bled through. You can the turn the machine on.
Cheers Ziggy.
Karcher G 2600... | Answered on Nov 30, 2012
Your pressure washer is equipped with a device called an "unloader valve". This valve allows the water to route into a by-pass loop when the trigger is not pulled. If you can locate a parts breakdown for your model (like in the owner's manual - hopefully), then you can locate the unloader valve and take it apart and with careful observation determine what has gone wrong with it. Most likely you will wind up ordering a kit that will have all the o-rings and etc that are part of the unloader (the wearable pieces). Just take your time and keep all the old pieces in order. You just want to be sure you can determine where the new pieces go.
If I were you, I would first contact a dealer for price/availability. But get the part # -- then you can shop around. Often its amazing how good prices can get on ebay, amazon, etc.
Good luck, and rate me if this is helpful to you. Thanks!
Don
Karcher G 2600... | Answered on Mar 15, 2012
Karcher G 2600 VH Gas Pressure Washer Logo
44 questions posted
Top Karcher Garden Experts
John Trevino
JOHN LAPIER
Joseph Mueller
Joseph Mueller
Are you a Karcher Garden Expert? Answer questions, earn points and help others
View Most Popular
Karcher Garden
  • Karcher Garden
Most Popular Question
karcher g2600vh honda engine gcv160 n5af
  • Garden
