Lost your photos on Android phone & need to recover deleted pictures, try GT Recovery for Windows- the World's 1st Data Recovery Software for Android smart phones.
It can directly recover deleted pictures, photos lost due to deleting, restoring factory settings, flashing ROM, rooting, etc., from SD cards inside Android devices. It let you preview the deleted photos before recovery. Watch the video tutorial to learn how to retrieve photos from Android phone easily with simple clicks.
Key features of Data Recovery - GT Recovery for Android:
1). Preview & selectively retrieve photos and video lost due to any problem
2). Support all Android phones/tablets, like Samsung, HTC, LG, Motorola...
3). Only read and recover the data, no personal info leaking, 100% safe
Yes, it's possible. A good digital camera photo recovery software can be used to recover deleted photos, or lost photo after accident memory card format. I'd recommend asoftech photo recovery as it helped me many times. download fromhttp://www.asoftech.com
as far as i think VISTA is not compailant with the CANON software. since vista s a latest version CANON will have to release a new version of its software for VISTA. so this must be requested with CANON.
Did you accidentally press the DISP button on the back of your camera? This manually turns the screen on and off to save batteries. Try pressing this button one more time to see if it turns the screen back on.
Your camera only can use SD cards. The SDHC is a newer generation of SD cards, that need a different protocol you access the files. The newest version is the SDXC version.
SD cards never exceed 4 Gbyte. The SDHC never are bigger than 32 GD and the SDXC are over 32 GByte.
When you try to buy a SD card, the biggest you will find will be 2 GByte. I own 2 SD cards that have 4 GByte, but even I can't find them on the net any more.
The cards are from Platinum. But I even can't guaranty you the 4Gbyte will work in your camera.
Some firms used to bring out new firmware, as soon as the SDHC cards came out. I succeeded to update my TomTom to SDHC and the old thing now even accepts 16 GByte cards. But Canon did not offer an upgrade for the V550, so you stay stuck to the normal SD cards.
Take no more pics until you've recovered the photos, take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for:
The reason this occurred is that you likely never formatted the card in your camera. The card will work fine in the beginning but eventually will corrupt. AFTER you've recovered the photos, format the card in your camera to prevent this from happening again (press function, select tools menu, select item stating your card's memory capacity, then follow the prompts for low-level format). Keep in mind formatting will also totally erase your card, so again only do this AFTER you've recovered the photos.
