20 Most Recent Logitech X-530 Computer Speakers Questions & Answers
Have you checked the fuse in your plug. If the fuse has blown it won't work in any wall socket. Change the fuse for a new one anyway, then try again.
Logitech X-530... | Answered on May 28, 2019
Liamog, i bought the exact same speakers and sound card, and i had the exact same problem as you. I tried for days to fix it and it turns out that its only a setting you have to enable in your sound card settigns. If you go into your EAX console for your creative sound card you will find a thing that sams CMSS 3D, and all you have to do is select the button that says Enable CMSS 3d surround. I hope this will fix your problem. Alex.
Logitech X-530... | Answered on May 17, 2018
I don't get it, You just have to connect the speakers to your sound card (5.1=3 connectors)
set your sound card to 5.1 output and that all. No drivers needed.
Logitech X-530... | Answered on Mar 15, 2018
You need an RCA - RCA cable,that means that you need a cable with RCA at both ends. At the back of the dvd player,look for sound section (RCA jack) In the sound section look for "right" and "left" connect the two RCA jacks in there and you`re done.
------- If you don`t know how an RCA jack looks like,see this image
Logitech X-530... | Answered on Mar 08, 2015
Primero trata con otra fuente de energia electrica otro tomacorriente u otro sitio a ver si no es el sistema de cornetas, para abrir el sub buffer solo encesitas destornilladores y verificar dentro el estaod de los componentes si tienes voltimetro mejor, cuidado con hacer cortos. pero no hay uan guia basica para eso, solo saber lo que haces.
Logitech X-530... | Answered on Apr 25, 2014
Did these come with a disk for installation? Did you check that the drivers are installed? Device Manager-Sound Devices.
Logitech X-530... | Answered on Mar 03, 2014
Logitech X-530 Computer Speakers Logo
535 questions posted
Top Logitech Audio Players & Recorders Experts
Ekse
Michial Gueffroy
Paul
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Audio Players & Recorders
Most Popular Question
logitech x530 computer speakers
  • Audio Players & Recorders
