20 Most Recent Logitech X-240 Computer Speakers Questions & Answers
There is no driver for analogue speakers. Possibly you need a driver for your sound device on that computer. Try another computer or other audio source on the speakers to verify they are working.
Logitech X-240... | Answered on Feb 08, 2015
Me 2, my remote broke, so I need to use its amplifier, but it does not receive power signal, I just need to know how to give power on signal from the 6 wires that connect the sub from the remote
Logitech X-240... | Answered on Jul 19, 2013
It's just "dirt" on the mechanical part of the volume-control. Either you take the speakers apart, and use denatured alcohol and Q-Tips(tm) to clean that part, or you replace the volume-control, or you replace the speakers.
Logitech X-240... | Answered on Feb 18, 2013
if your computer came with a motherboard disc the sound drivers could be on it
if you dont have a motherboard disk you will need to download the sound drivers
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope this helps
Logitech X-240... | Answered on Mar 13, 2012
Hello little richi,
I would suggest plugging your speakers into another outlet first to be sure that your speakers are the problem. I would then suggest to check and see if you can remove the power cord, which I would assume is universal and can bought at many retailers, and install a new one.
If the switch was the problem, this situation becomes more technical. You most likely would have to buy a new plug. There are electronics retailers such as Jameco and Newark. We're not talking about places like Best Buy and Walmart here. Jameco and Newark sell plugs that you would have to solder on to the wire. The plugs should be real cheap. If you know how to solder, all you would need to do is solder the wires on to the plug.
Logitech X-240... | Answered on Sep 06, 2011
clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Logitech X-240... | Answered on Aug 31, 2011
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers if you dont have a motherboard disc you will have to download the drivers
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
Realtek AC'97 audio driver package. The package includes: driver setup program, drivers for Vista/Windows 7 32-bit and 64-bit editions.
hope this helps
Update your embedded sound from Realtek to the latest AC'97 codec.
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or you can download the drivers
Download the driver software by
http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html free sound drivers
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
Realtek AC
Logitech X-240... | Answered on Jul 27, 2011
There is no software for your speakers. Here is the installation guide:
http://logitech-en-amr.custhelp.com/ci/fattach/get/391235//session/L2F2LzEvc2lkL3Z2NWVXWndr
Logitech X-240... | Answered on Jun 20, 2011
Logitech X-240 Computer Speakers Logo
124 questions posted
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Paul
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Audio Players & Recorders
Most Popular Question
just reformatted hard drive because
  • Audio Players & Recorders
