20 Most Recent
Zenith LX-140 CD Shelf System Questions & Answers
Clearing the presets on the radio HELP!
I did not get to whatt is required by you? did you mean to reset the radio channels that is already on preset.
If so use the manual mode to search for the frequency, once the selected frequency is fixed , press the memory to flash and select the preset of the location you want to be stored.
If you meant the question to be clearing all presets , just press and hold to an blank channel the memory and select location.
Can anyone help me fix some record players?
It's possible that there could be a problem with both record players. Here are some things to check:
For the Swingmate Concert Hall Automatic Record player:
- Check to make sure the power cord is securely plugged in and that the outlet it's plugged into is working.
- Check to see if there's a power switch on the back of the record player that needs to be turned on before the main power switch can be activated.
- Check to see if the main power switch is stuck or blocked in some way. If so, try gently pushing or pulling it to see if it will move.
For the Zenith 4 speaker stereophonic record player:
- Check to see if the knob is stuck or blocked in some way. If so, try gently pushing or pulling it to see if it will move.
- Check to see if there's a safety mechanism preventing the turntable from starting up. Some record players won't turn on if the tonearm is not in the correct position or if the record player cover is not closed.
If these suggestions don't work, it may be best to take the record players to a professional technician for further inspection and repair.
Zenith clock radio Z212B setting memory buttons
Press "display" and make sure the radio is displaying frequency, not time.
Tune the radio frequency you want to add to memory. Press "Memo Set" and observe that "preset" flashes on the display.
Press the number of the memory channel that you want to save to.
Press "Memo Set" and observe that "preset" on the display has stopped flashing.
The frequency is now saved the selected channel.
My zenith surround goes into protection mode after 15 minutes no sound
Disconnect your speakers when unit off and cold. Turn unit on and wait. If unit stays on, check speaker wiring for damage. Connect one speaker at a time with unit off and retest to find either a bad speaker or output channel problem. Repair speakers and wiring if found, or take unit for service, you have an overload problem.
