20 Most Recent Zenith XBS344 System Questions & Answers
I need to install a deutsch akustik d-85 surround
just install the woofer in the w offer position according with the diagram that is displayed on the speaker configuration on the driver ...(sound driver )...and if there is a second plug for the others ...probably it will fit from a main speaker in the green plug in in the back ....and from that will have wireless signal to the others ...or even from the woofer ...but another channel ...
another possibility is wireless from the main speaker ...but the cables are 2 for stereo out ......and from the main will be wireless to the other so ...no mater the distance so much as long as they are in range ...probably radio ...cause blue tooth require more tech...
12/15/2009 6:51:02 AM • Zenith XBS344... • Answered on Dec 15, 2009
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck [email protected]
1/7/2009 10:22:20 PM • Zenith XBS344... • Answered on Jan 07, 2009
Progressive Scan Mode
Check for video out in the dvd setup menu, and set it for composite,
It may be set for component.
another thing to try is setting the the progressive scan option off in the setup menu, you wont benefit from it, but at least it might work.
if you already tried using the prog scan and your T.V isnt compatible, you'll need to reset. press stop to stop any playing disc, and press stop again holding it for 5 seconds to reset the system.
good luck!
1/5/2009 10:31:53 PM • Zenith XBS344... • Answered on Jan 05, 2009
Install manuel
there is a manual here that you can look thru by clicking the numbers on the page or the next highlighted links
here is the start of the manual , just click the link http://www.fixya.com/support/p168537-zenith_xbs344_system/manual-6463
1/1/2009 7:02:00 PM • Zenith XBS344... • Answered on Jan 01, 2009
2answers
Dvd door
I had the same problem. It started after I plugged a PS2 into the system using the A/V cable ports in the front. I discovered just by unplugging the cables the door opened again.
5/15/2008 10:32:55 PM • Zenith XBS344... • Answered on May 15, 2008
Surround sound help
A few questions... What components are involved? How are they connected? Can you hear sound from the speakers for any other input device i.e. radio, cd, vhs, etc.? I suspect that there is an issue with the way the system is connected. I have the Surround sound output from my DVD player connected to the digital surround sound input on my reciever. I'm using digital coax cable (looks like a "normal" RCA cable), not the optical fiber connection. I had to buy a special cable for the digital surround sound. A normal RCA cable would not work. I don't know why. If you're using a similar connection, that could be your issue. make sure that the output and inputs you're using are compatible. A digital surround sound connection (in or out) can't be connected to an analog connector (in or out). Remember, Digital to Digital with a Digital capable cable; Analog to Analog with an Analog capable cable. If this is not your issue, post back here with more info and we'll see what we can figure out.
9/5/2007 4:58:03 AM • Zenith XBS344... • Answered on Sep 05, 2007
Copy VCR to DVD
you have to convert it.....best by a computer useing a video card to digital converter. then if I was you I would clean it up and edit using a nice software program like Liquid edition...but that is expensize just use the moviemaker that came with XP...after you finish you need another software program like Nero with a special progarom that converts to dvd from anything digital.Also you must have a dvd writer. Dvd are 4.7gigabyetes where as cd writers are 700 meg. good luck
8/31/2007 4:46:40 PM • Zenith XBS344... • Answered on Aug 31, 2007
Static/White Noise
Scroll down to the speaker set option. activate it then push the > button. You will see the test below the speaker diagram.
5/19/2007 7:36:41 PM • Zenith XBS344... • Answered on May 19, 2007
Dvd region usege
Nope sorry there is not a way to change regions. On the door problem there seems to be a problem with the timing of the gears or mechanism that closes the door system. Good luck
4/20/2007 10:08:03 PM • Zenith XBS344... • Answered on Apr 20, 2007
How can I take advantage of digital cable?
No digital sound comes from Digital Coax or Optical and in order to utilize a digital signal u need HDMI or Component although component wont be truly digital. Try running everything to the TV then the sound out of the TV into the sound system. If its a high def source like high def cable box then use the optical conection on the back of the aquos and plug than into your surround system. if ur system doesnt support Optical or digital coax then you need an updated surround system. If i misunderstood your question im sorry. If u live in CT though stop by Circuit city in North haven. either myself, Dave, or my associate Justin should be able to help you out. and dont worry we're not on commission or anything.
2/3/2007 5:14:30 AM • Zenith XBS344... • Answered on Feb 03, 2007
Disc error
Did you try cleaning the lens yet??? If the lens is not dirty and you have no electronic equipment like an osciliscope, and test alighnment disc theres not alot a consumer can repair on these units. Sorry. Good Luck
6/26/2006 4:00:32 AM • Zenith XBS344... • Answered on Jun 26, 2006
I have a Zenith Z50P3, and I'm attempting to connect a newer Soundbar to it. Anyone know how?
It is an old 2007 Set. Upgrade the television, the soundbar has left it behind in software terms. https://www.manualslib.com/manual/646773/Zenith-Z42p3.html#product-Z50P3%20and ..
3/9/2023 4:03:06 AM • Zenith Audio... • Answered on Mar 09, 2023
Can anyone help me fix some record players?
It's possible that there could be a problem with both record players. Here are some things to check: For the Swingmate Concert Hall Automatic Record player:
  • Check to make sure the power cord is securely plugged in and that the outlet it's plugged into is working.
  • Check to see if there's a power switch on the back of the record player that needs to be turned on before the main power switch can be activated.
  • Check to see if the main power switch is stuck or blocked in some way. If so, try gently pushing or pulling it to see if it will move.
For the Zenith 4 speaker stereophonic record player:
  • Check to see if the knob is stuck or blocked in some way. If so, try gently pushing or pulling it to see if it will move.
  • Check to see if there's a safety mechanism preventing the turntable from starting up. Some record players won't turn on if the tonearm is not in the correct position or if the record player cover is not closed.
If these suggestions don't work, it may be best to take the record players to a professional technician for further inspection and repair.
2/26/2023 6:25:40 AM • Zenith Audio... • Answered on Feb 26, 2023
Zenith ZG120W. Old am/fm clock radio flashing..
Some have a backup battery in the back or the base. Flashing normally is an indication that here has been a power cut.
1/25/2022 3:51:23 AM • Zenith Audio... • Answered on Jan 25, 2022
3answers
Need manual for vintage zenith 7050 receiver
Sounds like a bad potentiometer Here you go. Click here: https://www.hifiengine.com/manual_library/zenith/mc7050.shtml
9/14/2019 11:19:01 PM • Zenith Audio... • Answered on Sep 14, 2019
Where can I get a User Manual and Guide for my Zenith Z358 Clock Radio?
Seems impossible to find. There was directions posted on FixYa which gave directions to a different Zenith models. While not the same, you may find the directions to this model similar to your Z358.
http://www.fixya.com/support/t23768010-set_time_zenith_z1233ba
6/30/2019 3:22:05 AM • Zenith Audio... • Answered on Jun 30, 2019
Zenith XBS344 System Logo
17 questions posted
Popular Products
Top Zenith Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Zenith Audio Players & Recorders
Most Popular Question
install manuel
  • Audio Players & Recorders
