20 Most Recent
Zenith XBS444 System Questions & Answers
I cant watch any dvds,
hi,
ur dvd is in progressive scan mode. u have to get out of that setting ,because ur TV dosen't supports the progressive scan. do the following to get out of the progressive scan mode.
1. power ON the dvd.
2. press stop button to stop any disc that is playing.
3. press stop again and hold it for five seconds.
the video out will be restored to the standard settings.
ok
Hi. I'm trying to play a homemade dvd with several
The dvd may be in the wrong format for your Son's t.v. PS3's play several formats that the lifestyle 38 may not be compatible with. You can download a video converter such as Any Video Converter and format the disc for whatever format you need. Probably mpeg2. Then it should play on most players.
Same Problem, Speakers Do Not Turn On
If it's still under MFG. Warranty, get it replaced. If not, weigh the cost of repair vs. replacement. What has more than likely happened is the unit has seen either a "Brownout" severe voltage drop then spike to commence power, or a power surge. It's a very common problem with today's electronics of all kinds. It will either have a bad power supply or bad transistors and will range from $ 125.00 - $ 175.00 to repair on avg. When you have it replaced or repaired, make sure you purchase a good line conditioning surge protection unit like Monster, Panamax, or Furman. Not a power strip, that's just a glorified light switch. Sorry for the bad news! Hope this helps
Progressive Scan
SOLUTION #1
you'll need to reset. press stop to stop any playing disc, and press stop again holding it for 5 seconds to reset the system.
SOLUTION #2
works with remote only
SOULTION #3
While Disc is Running,
By using remote control,
Press Stop Button once to stop the disc (Stop in Memory Mode)
Press Stop Button once again to go into Full Stop
Then, Press & Hold Stop Button for 5 Second or So.
GOOD LUCK!
koreanainusa
Zenith XBS444 shuts off
I just posted the fix for this problem under the post of davidlentz who is having the same problem. Problem is IC706 located on the audio output board Part number is KIA7805A.
No audio for tv?
Since not all devices have the same in/outputs available, if you are trying to interconnect them, it helps to know the make and model of both, not just one.
There are several possibilities to connect external devices to your 'home theatre' system.
The one we have delivers the best when S-video is used but that requires a separate path for sound.
The standard colors for audio in and outputs are red(=right) and white(= left) and often cables are supplied with the same color coding.
The usual connections will be named 'Line in' and 'Line out.' The outputs deliver specified voltage into a specified load (or termination) and the inputs expect that condition.
This ensures that volume controls act in a sensible manner.
Audio problem
signs of a defective Filter Capacitor. I suggest you replace all capacitors in the Power supply and try.
Can anyone help me fix some record players?
It's possible that there could be a problem with both record players. Here are some things to check:
For the Swingmate Concert Hall Automatic Record player:
- Check to make sure the power cord is securely plugged in and that the outlet it's plugged into is working.
- Check to see if there's a power switch on the back of the record player that needs to be turned on before the main power switch can be activated.
- Check to see if the main power switch is stuck or blocked in some way. If so, try gently pushing or pulling it to see if it will move.
For the Zenith 4 speaker stereophonic record player:
- Check to see if the knob is stuck or blocked in some way. If so, try gently pushing or pulling it to see if it will move.
- Check to see if there's a safety mechanism preventing the turntable from starting up. Some record players won't turn on if the tonearm is not in the correct position or if the record player cover is not closed.
If these suggestions don't work, it may be best to take the record players to a professional technician for further inspection and repair.
Zenith clock radio Z212B setting memory buttons
Press "display" and make sure the radio is displaying frequency, not time.
Tune the radio frequency you want to add to memory. Press "Memo Set" and observe that "preset" flashes on the display.
Press the number of the memory channel that you want to save to.
Press "Memo Set" and observe that "preset" on the display has stopped flashing.
The frequency is now saved the selected channel.
