20 Most Recent Euro-Pro Fast and Easy 420 Mechanical Sewing Machine Questions & Answers
How can I stop bobbin thread from jamming
This is usually caused by the needle not being threaded correctly or wrong size needle or wrong thread for the material or old thread, or incorrect tension for the material being sewn.
11/3/2017 5:51:48 AM • Euro-Pro Fast... • Answered on Nov 03, 2017
How can I repair my automatic needle threader, it's in 2 pieces
YOu cant' You used to be able to buy a new unit at Europro for $10. But don't know if they are still in business. I gave up on mine and do it manually.
11/3/2017 5:48:08 AM • Euro-Pro Fast... • Answered on Nov 03, 2017
Brother machine thread coming out of needle
Wet and dry fine paper rub the walker foot and base for any catching.
10/20/2017 11:27:09 AM • Euro-Pro Fast... • Answered on Oct 20, 2017
Looping bottom thread
Check your tension on reel.
6/3/2015 5:59:12 AM • Euro-Pro Fast... • Answered on Jun 03, 2015
Sewng machine fails to loop on bottom bobbin
There are several possible causes for this problem.Simplest first. 1) The machine has sat in the closet for three or more months, and the oil has ceased. The fine oil requried for these precision machines does run away, and/or cease up into a grease like paste, causing the parts that move in precise harmony, to be not so precise. The cure for this, is to remove all thread and fabric, and run the machine full speed for about two to five minutes. This heats up the parts and loosens up ceased parts. A good re application of fresh oil helps too.NOTE: Check the needle is Straight by turning the machine a couple of turns by hand and seeing that the needle dosn't hit any metal parts. A breaking needle can cause dammage to the machine or user in when operating at high speeds.2) Tension dials have been knocked out of balance. There is a numbered tension dial on the front of the machine, somewhere along the threads path from spool to needle. if this is too tight, the thread will not leave a loop big enough to catch the bottom thread. Be sure this is set to about 3, usually. It should be adjusted while stitching, when you get to that point.On the bottom thread, on the Bobbin Holder piece that comes out of the bottom, there is a small screw that adjusts tention of the thread comming out. This screw should not be tight, but tight enough. Completely by tactile intuition, this screw should be adjusted to allow the thread to slide out of the bobbin holder smoothly. It must have some tension to pull the thread from it, but not so much that it is noticeable, or take much of a grip on the thread to pull it out. (difficult to describe) These two tensioners must balance so the threads, cross paths, but also pull the stitched snugly into the fabric being sewed.3) Bent Needle, this is a problem if the fabric being sewed has pulled the needle off it's center. If it is not perfectly straight, don't use it.4) Cheap thread can be a problem. If the thread is frayed, or fuzzy looking, it may be that it will not work with as fine a needle you are using. Needles have various sizes and sized holes to feed the thread through, a fine needle needs fine thread, and coarse thread needs a larger needle.These are the primary causes of the threads not looping together properly. I hope this helps.
7/25/2014 6:52:49 PM • Euro-Pro Fast... • Answered on Jul 25, 2014
Machine fails to loop thread thru the needle
I presume that you are talking about an automatic needle threader? In this case, first of all check that the needle is correctly in place -- inserted all the way up as far as it can go. Then manually turn the wheel so that the needle is in the high position. If this doesn't fix the problem, then maybe your needle is bent, so replace it.
7/25/2014 8:25:16 AM • Euro-Pro Fast... • Answered on Jul 25, 2014
How to bring up bottom thread
Be sure you leave a 3-4" tail on the bobbin when you insert it. Hold the end of the top thread, turn the fly wheel toward you until the needle goes down into the bobbin, grabs the bobbin thread and pulls it up. Take both threads toward the back of the machine and pull out about 6". Hold both threads as you take the first stitch in your fabric.
7/25/2014 12:43:35 AM • Euro-Pro Fast... • Answered on Jul 25, 2014
Install bobbin in euro-pro X 464XC
Either your machine was not threaded with the presser foot wasn't up when you threaded the upper thread... or your upper tension isn't tight enough. Good luck.
4/24/2014 2:10:55 AM • Euro-Pro Fast... • Answered on Apr 24, 2014
0answers
I do not have a manual. How does the bobbin cover
here is a link for a manual, the manual is not free, euro-pro normally aren't. but it should have the information you need in it.http://sewusa.com/Sewing_Machine_Manuals/Euro_Pro_Sewing_Machines/Euro_Pro_420_Instruction_Manual.htm
9/6/2013 4:18:36 PM • Euro-Pro Fast... • Answered on Sep 06, 2013
Presser foot wont raise
have u tried wd 40? and or check presser to see if pin is bent
9/16/2012 12:40:22 AM • Euro-Pro Fast... • Answered on Sep 16, 2012
How to thread an Euro-prox 464xc?
can u show a video?
9/14/2012 1:07:02 AM • Euro-Pro Fast... • Answered on Sep 14, 2012
The threader to the needle wont catch the thread
It takes some getting used to, to get these to work properly. Practice. First make sure your needle is in correctly and fully. then make sure that when you engage the needle threader the tiny little hook goes through the eye of the needle. If it doesn't it won't work at all. Then follow the instructions in the book. Make sure the thread is on the proper side of the tiny hook.... Good luck
9/5/2012 4:31:02 PM • Euro-Pro Fast... • Answered on Sep 05, 2012
2answers
Mitsubashi belt B 156 XXL 6.1
check with these sitessewusa.comsewingpartsonline.comsewvacdoctor.com
4/7/2012 7:05:12 AM • Euro-Pro Fast... • Answered on Apr 07, 2012
Euro-Pro Fast and Easy 420 Mechanical Sewing Machine Logo
68 questions posted
Top Euro-Pro Sewing Machines Experts
Mike Cairns
Mike Cairns
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Euro-Pro Sewing Machines
Most Popular Question
threader needle wont catch thread
  • Sewing Machines
