20 Most Recent Patton PUH680-U Utility Heater Questions & Answers
2answers
Coils not all working
the heating coil may be broken and shorting out to the case. it is a nichrome resistance wire. replace it.
1/12/2019 1:19:45 PM • Patton PUH680-U... • Answered on Jan 12, 2019
2answers
Starts then shuts off
My Mighty Heater 1500 will run for 15sec then shuts off then repeats it over an over
11/16/2018 7:01:37 AM • Patton PUH680-U... • Answered on Nov 16, 2018
Heat 1 & 2
Typically 'Heat 1' means first stage heat and 'Heat 2' means second stage heat. Essentially a Lo and Hi setting. Just like a hair dryer.
1/1/2015 9:48:51 PM • Patton PUH680-U... • Answered on Jan 01, 2015
0answers
0answers
Plug
Be the first to answer 4/2/2014 4:34:43 AM • Patton PUH680-U... • Posted on Apr 02, 2014Be the first to answer
0answers
Problem with mighty heater 1500
M y mighty heater 1500 kicks on runs for 15sec and kicks off on & off on& off what do I need
1/29/2014 11:02:20 PM • Patton PUH680-U... • Answered on Jan 29, 2014
0answers
0answers
2answers
I need the lighted switch on front of Patton
MILKHOUSE HEATER "CAUTION LIGHT" SOLUTION: Before I explain, let me clear this myth up: this is NOT an issue with the pendulum safety switch (some mistake that for a "mercury" switch). To begin, unplug the heater. Open it up and clean it out. I mean, buy a can of non-chlorinated brake cleaner and squirt all of the contacts good. Below the fan there is a sensor mounted on the heater element box on the bottom. That goes bad and causes it to trip. While you are there, squirt the motor bushings good with the brake cleaner and dab a drop of synthetic motor oil (just a drop) on EACH of the two motor bushings. Personally, I rewired this and bypassed all of the safety features. You can bypass that sensor without soldering or cutting any wires. All you have to do is unscrew the wires from the holder and then unscrew the tiny nuts and tiny bolts. Then bolt the together at one end (note the position) and put it back in the holder and tighten the screw to hold it in. This method fixes the issue completely as it removes the sensor from the equation. In fact, I just did that on my third milkhouse heater and it has been running solid for the last 15 minutes. Use your modified heater with caution! Let the brake cleaner dry before you energize this device!
12/11/2012 11:54:18 PM • Patton PUH680-U... • Answered on Dec 11, 2012
Patton PUH680-U Utility Heater Logo
86 questions posted
Top Patton Heating & Cooling Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Paul Carew
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Patton Heating & Cooling
Most Popular Question
heat 1 amp 2
  • Heating & Cooling
