20 Most Recent Patton PQH307UM Electric Utility Heater Questions & Answers
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
12/16/2018 6:14:27 PM • Patton PQH307UM... • Answered on Dec 16, 2018
2answers
What does the sertting with the number one and
ONE SHOULD BE LOW 2 SHOULD BE HI ,FANS ARE HARD TO HEAR DO TO THE FACT IT IS A RADIANT HEATER.
1/30/2018 9:51:08 PM • Patton PQH307UM... • Answered on Jan 30, 2018
Can purchase replacement parts
Check on google; 1000SW and 1500W
1/19/2016 11:30:24 PM • Patton PQH307UM... • Answered on Jan 19, 2016
IT OVER HEATS IN ABOUT 15 MIN OF USE. ONLY ABOUT 3
There are a few things that I can think of, your air intake is on the top make sure they are clear. The fan is a little thing, is it running and can you feel the air being pushed out? I count eleven screws on the back of my heater so remove all eleven screws clean air passages and look to see if the over heating sensor is in its mounting or is it hanging free.You can take it apart and clean it, just do not touch the heating elements and make sure you have it unplugged!!
12/14/2010 5:25:26 PM • Patton PQH307UM... • Answered on Dec 14, 2010
When the heater cycles off,
personally? i would toss it, that sputtering could be the control switch arching inside
10/22/2010 12:35:34 AM • Patton PQH307UM... • Answered on Oct 22, 2010
Have a patton space heater. Light is on when plugged in but will not start. Can you tell me how to fix?
If the light on your Patton space heater is on, but the heater will not start, there are a few things you can try to fix the issue:
  1. Check the power source: Make sure the heater is plugged into a working outlet and that the circuit breaker or fuse is not tripped.
  2. Check the thermostat: Make sure the thermostat is set to a temperature higher than the current room temperature. If the thermostat is set too low, the heater will not turn on.
  3. Check the safety features: Some space heaters have safety features, such as a tip-over switch or overheating protection, that will shut off the heater if it is not positioned properly or if it gets too hot. Check to make sure the heater is positioned correctly and not too close to anything that could cause it to overheat.
  4. Clean the heater: Over time, dust and debris can accumulate in the heater, which can cause it to malfunction. Unplug the heater and clean it thoroughly, making sure to remove any debris from the heating element.
If none of these steps resolve the issue, there may be a problem with the heater's internal components. In that case, it is best to contact the manufacturer or a qualified repair technician for further assistance.
2/26/2023 10:18:45 AM • Patton Heating &... • Answered on Feb 26, 2023
How can I order the manual of Patton #POH2420?
Unfortunately you can't. These are made overseas and badged to whomever sells them. The manual for the 9000 model is available, but not yours. This may be the closest? http://www.useandcaremanuals.com/pdf/WOFH7167.pdf https://www.google.com/search?q=Patton+POH2420+manual ..
11/5/2021 2:27:33 AM • Patton Heating &... • Answered on Nov 05, 2021
What website will have the Patton AccuTemp floor heater Model POH2420?
I would try the manufacturers web site.
11/2/2021 6:37:37 PM • Patton Heating &... • Answered on Nov 02, 2021
My dad let me use his Patton PRH11 120v 60hz 1500watt heater and when I plug it in no light or nothing comes on?
Check the base for a tip over safety switch. It needs to be pressed in. Can't find a manual for it as it appears to be an Amazon, Walmart special. Try it in another outlet, or put something else in that outlet that is known to work like your cellphone charger. https://www.walmart.com/ip/Patton-Radiant-Heater/15126054 https://www.google.com/search?q=Patton+PRH11+manual .. ..
6/10/2021 6:03:17 PM • Patton Heating &... • Answered on Jun 10, 2021
Patton PQH307UM Electric Utility Heater Logo
20 questions posted
Top Patton Heating & Cooling Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Paul Carew
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Patton Heating & Cooling
Most Popular Question
sertting number one
  • Heating & Cooling
