20 Most Recent Patton PRH11 Electric Heater Questions & Answers
the beeping could be caused by the tip switch malfunction. The best thing to do is call for a warrentee replacement @ https://secure.pattonproducts.com/ContactUs.aspx
Patton PRH11... | Answered on Mar 05, 2011
May be loose screw in frame, element is old or insulator is worn
Patton PRH11... | Answered on Jan 10, 2011
These heaters all have safety devises in them some for tip over and all for over heating. Your problem sounds as if it has a bad over heating sensor. These will have two wires one in one out, it is usually a positive wire. When they sense that the heater is to hot it shuts it down upon cooling it allows the heater to turn back on. The tip switch does the same if upright it turns on if tipped it turns it off. They are mechanical and thermal switches and they do go bad. These can be jumped out to trouble shoot the problem but I would not run it with out these safety devices in it.
Patton PRH11... | Answered on Dec 21, 2010
Wires are rated to handle a certain amount of amps. Your dryer cord is bigger than your coffee maker cord because your dryer pulls more amps. What is going on with your heater is your heater is drawing more amps than the wire can handle. Therefore the wire is getting hot, melting the insulation. Hopefully it shorts out before it catches on fire!!! BOTH BAD SCENERIOS!!! It is possible your machine is just excessively dirty, therefore working extremely hard, drawing high amps. If you are able to give a good cleaning, do so. Let dry and turn heater on DURING A TIME WHEN YOU CAN MONITOR IT, NOT OVERNIGHT. See if it has made a significant improvement. If not, it's time for a new heater!! Best Wishes!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Patton Heating &... | Answered on Nov 28, 2017
Patton PRH11 Electric Heater Logo
Popular Tags
22 questions posted
Top Patton Heating & Cooling Experts
Jay Finke
Jay Finke
ray gallant
ray gallant
jeff5may32
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Patton Heating & Cooling
Most Popular Question
patton prh11 heater keeps
  • Heating & Cooling
