20 Most Recent Patton MH761 Utility Heater Questions & Answers
0answers
Red caution light
The red light is in conjunction with a safety. This is there in case something goes wrong, the heater doesn't overheat and possibly catch fire. If its not getting too hot, and its sounds like its not. The safety needs to be replaced. It will be a little disc shaped thing with 2 wires connected to it. If this heater also has a tip over safety, there also may be some type of mercury switch too. If you are so inclined, when you find the safety disc it should have some numbers on it. This indicates the temperature it is made to turn off at. After removing it, connect the 2 wires together and turn the unit on with a thermometer in the spot where the disc was. If the temp. doesn't go higher than the #'s on the disc after 45 seconds like you said, then you know positively that is the problem. If it gets hotter very fast, then the elements need to be looked at for defects. If there are no numbers on the disc or you cant find a replacement, then it may just be easier to buy a new heater.
12/11/2012 11:49:46 PM • Patton MH761... • Answered on Dec 11, 2012
Do they use a lot of electric?
Oh yes depending on the draw amps they can run you an extra 50 bucks a month using it 4 hrs a night .
11/29/2010 7:18:34 PM • Patton MH761... • Answered on Nov 29, 2010
Have a patton space heater. Light is on when plugged in but will not start. Can you tell me how to fix?
If the light on your Patton space heater is on, but the heater will not start, there are a few things you can try to fix the issue:
  1. Check the power source: Make sure the heater is plugged into a working outlet and that the circuit breaker or fuse is not tripped.
  2. Check the thermostat: Make sure the thermostat is set to a temperature higher than the current room temperature. If the thermostat is set too low, the heater will not turn on.
  3. Check the safety features: Some space heaters have safety features, such as a tip-over switch or overheating protection, that will shut off the heater if it is not positioned properly or if it gets too hot. Check to make sure the heater is positioned correctly and not too close to anything that could cause it to overheat.
  4. Clean the heater: Over time, dust and debris can accumulate in the heater, which can cause it to malfunction. Unplug the heater and clean it thoroughly, making sure to remove any debris from the heating element.
If none of these steps resolve the issue, there may be a problem with the heater's internal components. In that case, it is best to contact the manufacturer or a qualified repair technician for further assistance.
2/26/2023 10:18:45 AM • Patton Heating &... • Answered on Feb 26, 2023
How can I order the manual of Patton #POH2420?
Unfortunately you can't. These are made overseas and badged to whomever sells them. The manual for the 9000 model is available, but not yours. This may be the closest? http://www.useandcaremanuals.com/pdf/WOFH7167.pdf https://www.google.com/search?q=Patton+POH2420+manual ..
11/5/2021 2:27:33 AM • Patton Heating &... • Answered on Nov 05, 2021
What website will have the Patton AccuTemp floor heater Model POH2420?
I would try the manufacturers web site.
11/2/2021 6:37:37 PM • Patton Heating &... • Answered on Nov 02, 2021
My dad let me use his Patton PRH11 120v 60hz 1500watt heater and when I plug it in no light or nothing comes on?
Check the base for a tip over safety switch. It needs to be pressed in. Can't find a manual for it as it appears to be an Amazon, Walmart special. Try it in another outlet, or put something else in that outlet that is known to work like your cellphone charger. https://www.walmart.com/ip/Patton-Radiant-Heater/15126054 https://www.google.com/search?q=Patton+PRH11+manual .. ..
6/10/2021 6:03:17 PM • Patton Heating &... • Answered on Jun 10, 2021
2answers
Patton PQH307
Wires are rated to handle a certain amount of amps. Your dryer cord is bigger than your coffee maker cord because your dryer pulls more amps. What is going on with your heater is your heater is drawing more amps than the wire can handle. Therefore the wire is getting hot, melting the insulation. Hopefully it shorts out before it catches on fire!!! BOTH BAD SCENERIOS!!! It is possible your machine is just excessively dirty, therefore working extremely hard, drawing high amps. If you are able to give a good cleaning, do so. Let dry and turn heater on DURING A TIME WHEN YOU CAN MONITOR IT, NOT OVERNIGHT. See if it has made a significant improvement. If not, it's time for a new heater!! Best Wishes!! If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
11/28/2017 1:58:55 PM • Patton Heating &... • Answered on Nov 28, 2017
Patton MH761 Utility Heater Logo
15 questions posted
Top Patton Heating & Cooling Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Paul Carew
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Patton Heating & Cooling
Most Popular Question
use lot electric
  • Heating & Cooling
