20 Most Recent HP Photosmart C6380 All-In-One InkJet Printer Questions & Answers
3answers
My printer i offline, hw do i i this?
This printer requires you turn it on first and then hit print on your document. If you do not turn it on first, you get a printer offline error message.
12/23/2022 11:00:26 AM • HP Photosmart... • Answered on Dec 23, 2022
2answers
I get this error message : General Printer Error
Generally, this is Hardware Failure Error on HP Printers. You may try few steps before considering it is Hardware Failure.
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
If you still get this error,
Remove the Cartridges and Printhead
( Printheads are that hold the cartridge and it has a latch on right side to loose to remove the Printhead, if you dont find a latch, your printer does not has Printhead. Generally, Printers with only 2 cartridges do not have Printheads and any printer beyond this with 4,5 or 6 cartridges have printheads. Sometimes the cartridges are on left side or printer and Printheads inside the printer after you open front access door or you will find cartridges and printhead both inside the printer if you open the front access door )
Clean the contacts ( Electrical or Golden contacts ) using lint free cloth. ( Cloth damped with few drops of water, squeezed properly )
Put the Printhead and Cartridges back and Turn off the printer and turn on.
If you have completed all the steps listed above and are still experiencing a problem, Service the product as it needs repair.
If your printer is In-Warranty, Contact HP Tech support - 1800-474-6838 and they should be able to replace it without charges.
Regards,
Ron,
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
3/5/2021 3:40:01 PM • HP Photosmart... • Answered on Mar 05, 2021
Error code 0x61011beb
Hi,This seems to be Printer failure error. The best you can expect the printer to work is with the steps below.Remove all the cartridges from the printer. Wipe the electrical ( tiny golden contacts ) with Lint free cloth. Disconnect the power cord from back of printer and while holding the power and cancel button - connect the cord. Release the buttons after 2-3 seconds.It should prompt you to install cartridges. Hope everything goes smooth, if not it could be hardware related issue. You can also contact HP on 1-800-474-6836 for further information.Regards,Sean
3/23/2020 10:09:50 AM • HP Photosmart... • Answered on Mar 23, 2020
3answers
Hp 6380 error message 0xc19a0023
Applicable error codes
This document applies to Ink System Failure error messages with any of the following codes:
0xC19A0001, 0xC19A0002, 0xC19A0003, 0xC19A0006, 0xC19A0008, 0xC19A0009, 0xC19A0013, 0xC19A0014, 0xC19A0015, 0xC19A0020, 0xC19A0021, 0xC19A0022, 0xC19A0023, 0xC19A0024, 0xC19A0025, 0xC19A0026, 0xC19A0027, 0xC19A0028, 0xC19A0030, 0xC19A0033, 0xC19A0034, 0xC19A0035, 0xC19A0036, 0xC19A0037, 0xc19A0040, 0xc19A0041, 0xc19A0042, 0xC19AC001, 0xC19AC002, 0xC19AC004, 0xC19AC008, 0xC19AC010, 0xC19AC020, 0xC19AC040, 0xC19AC063, 0xC19AC080, 0xC19AC0a5, 0xC19AC0c6, 0xC19AC0e7, 0xC19AC100, 0xC19AC129, 0xC19AC14a, 0xC19AC16b, 0xC19AC18c, 0xC19AC1ad, 0xC19AC1ce, 0xC19AC1ef, 0xC19AC200, 0xC19AC231, 0xC19AC252, 0xC19AC273, 0xC19AC294, 0xC19AC2b5, 0xC19AC2d6, 0xC19AC2f7, 0xC19AC318, 0xC19AC339, 0xC19AC35a, 0xC19AC37b, 0xC19AC39c, 0xC19AC3bd, 0xC19AC3de, 0xC19AC3ff, 0xC19AC400
HP Photosmart C6380 and others
Hi
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
1/31/2020 10:06:28 AM • HP Photosmart... • Answered on Jan 31, 2020
3answers
Photosmart C6380 All-In-One InkJet Printer: Ink system failure message appears on C6380 HP ...
You may want to try this link:http://www.out-of-warranty.com/ink-system-failure-error-0xc18a-hp/ It has helped fixed a lot of ink system failure issues..
2/4/2019 4:25:54 AM • HP Photosmart... • Answered on Feb 04, 2019
2answers
0xc19a0036
http://h30434.www3.hp.com/t5/Other-printing-questions/Ink-System-Failure-message-0xc19a0036/m-p/281228
1/30/2019 8:10:44 PM • HP Photosmart... • Answered on Jan 30, 2019
3answers
Printer wont print there is a message that says
Hi
1/30/2019 8:07:20 PM • HP Photosmart... • Answered on Jan 30, 2019
2answers
Hp photosmart C6380 Keep getting ink
1/30/2019 8:06:17 PM • HP Photosmart... • Answered on Jan 30, 2019
2answers
0xc19a0036
1/30/2019 8:04:11 PM • HP Photosmart... • Answered on Jan 30, 2019
2answers
Ink System Failure - 0xc19a0036
Same fix for this printer
1/30/2019 8:03:53 PM • HP Photosmart... • Answered on Jan 30, 2019
2answers
2answers
Hello, I'm having trouble with
With regards to your problem, please try the procedures below.
1. Reset the system numerous times. including disconnecting and reconnecting the power.
2. Followed the "Remove, clean, and reinstall the printhead" instructions - Did not work
Next step recommended: Replace the printhead If the steps above did not solve the problem, the printhead should be replaced.
8/8/2018 5:02:58 AM • HP Photosmart... • Answered on Aug 08, 2018
My HP Photosmart C6380 all in One is now printing
To see which color is having an issue, go to printer control panel and select "settings" > Tools> Print report> Print Quality report. When the page prints out, you will see which color is the problem. After you have figured that out, make sure the problem is not with the cartridge. If you see lines or missing colors, clean the printhead by removing it from printer(open cover, lift gray latch on the right side of the cartridges, remove cartridges and the printhead will easily slip out by pulling up) then soak the printhead in half inch deep amount of window cleaning solution. Preferably warm. Let soak at least 3 hours. Dry out the printhead and wipe rear conacts from moisture and dirt. Reinstall into printer and see the results. -Alex 303Electronics eBay Stores http://www.303electronics.com/ If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
6/1/2017 9:30:13 PM • HP Photosmart... • Answered on Jun 01, 2017
I just purchased the HP
Suggest you return it and buy Canon or Epson
5/28/2017 12:21:03 AM • HP Photosmart... • Answered on May 28, 2017
2answers
Hp c6380 scanner issues
Contact HP for Care at 1-800-585-2494.
12/15/2016 10:04:44 AM • HP Photosmart... • Answered on Dec 15, 2016
2answers
Error message carriage jam and/or paper jam
Often a carriage jam is caused by a paper jam. If you're getting a carriage jam message and a paper jam message, this video should help.
utube.png You-Tube video "wPjahOY5CDo" placeholder
8/11/2015 5:47:32 PM • HP Photosmart... • Answered on Aug 11, 2015
How to make HP C6380 print black & white only
You should be able to go into your printer preferences or properties settings by going to the "Printers & Devices" tab. If this is for Widows 8 or 8.1 I have not upgraded to either OS and have no clue as to their layout for access. In XP and 7 there is the option of changing your default settings from color/auto to black & white only. Make sure you hit the "APPLY" button to set it "OK" button doesn't always keep the settings locked in.
11/27/2014 12:08:11 AM • HP Photosmart... • Answered on Nov 27, 2014
HP Photosmart C6380 All-In-One InkJet Printer Logo
416 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
