20 Most Recent Jura Capresso Impressa E75 Espresso & Coffee Maker Questions & Answers
Try using warm water in the watertank, important that the water is not too hot, it can cause leakage in the o-rings in the fluidsytem.
Repeat the procedure a few times, if nothing helps, turn off the machine and wait 1 hour and try again.
If you can`t get around this message, then the flowmeter needs to be changed.
Jura Capresso... | Answered on Apr 10, 2019
Open the drawer and take out the box for the grounds. Run a rinse cycle and it should now go back into place.
Jura Capresso... | Answered on Sep 08, 2016
Do you seem to end up with more water in the tray now then you did before this problem started? Does your coffee seem weaker then before? If so I have some ideas for you.
Mike
Jura Capresso... | Answered on Sep 04, 2016
Hi, I made a video how to fix your Jura step by step, good luck... http://fixandparts.wix.com/nicknicoloudis#!jura-coffee-machine/c15gy
Jura Capresso... | Answered on Mar 23, 2015
I have some good instructions I downloaded from www.kaffeestudio.com . They are in German, but with many pics. If you are technically adept, then it is really no prblem. You should put in new o'rings and lubricate with the food grade silicon grease before reassembly, otherwise it won't be long before you are doing it again. Give yourself about 3 hours to perform this task the first time. One thing to remember. The cleaning tablets tend to strip the lubrication from the brew units, subsequently binding up the brew unit, sometimes tearing the o'rings and giving the malfunction 8. Plan on this being an ongoing maintenance exercise. Plan on at least once every year or two to have to do this.
Jura Capresso... | Answered on Jan 12, 2013
The tap is the dial on the left turn it, then it will turn the tap off. If it is repeating this then it may need to be decalcified.
Jura Capresso... | Answered on Sep 09, 2012
Malfunction 8 is related to the brew unit typically. It is usually an indication of the brew unit motor having to work too hard to move the brew unit up and down. This is usually cured by disassembling, cleaning, replacing any o'rings that may be bad, and lubricating the unit, then reassembly.
I have had to do this twice on an an E75 and an E8. I finally broke down and bought seal kits and lubricant for doing this. One could by a new brew unit off of e-bay and change out the whole thing. But a simple rebuild will typically suffice.
Mike
Jura Capresso... | Answered on Jul 02, 2012
Brew unit needs repair or replacement. www.hotncold.com
Jura Capresso... | Answered on Feb 25, 2012
how fine is your grind set to if it is to fine the water will not be able to get threw ,
Jura Capresso... | Answered on Dec 20, 2009
I have found seal/o-ring kits available on ebay Germany. Make sure you get the food grade lubricant to apply to the seals as well.
Mike
Jura Capresso... | Answered on Jul 05, 2009
Blazer,
I can help with this. I have become fairly well versed from owning two machines (an E-75 and an E-8) and having to repair them ocassionally. The guts in many of the Jura machines are typically very similar and utilize many of the same / similar components.
But it would be easier to handle via e-mail so that I can send pics of the inside of the machine and explain what's going on and what to look for. It will be much easier than explaining via this website. Just to alleviate concerns, it's most likely a simple o'ring issue.
I can be reached at mykr@yahoo.com.
Mike
I would remove the coffee spout and check the lines into it. The coffee seems to stop when it hits the spout and goes through the by pass instead. Remove the spout(be careful) then run a coffee and see if it works.
Jura Capresso... | Answered on May 26, 2009
I just called the company with the same problem today. They will fix your machine for free. They have recalled this machine. Call them and they will tell you what to do. 201-767-3999
Jura Capresso... | Answered on Mar 20, 2009
Jura Capresso Impressa E75 Espresso & Coffee Maker Logo
41 questions posted
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Impressa Jura Capresso
  • Impressa Jura Capresso
Most Popular Question
jura impressa e75 message mafunction 8
  • Coffee Makers & Espresso Machines
