20 Most Recent Jura Capresso Impressa S90 Espresso Machine Questions & Answers
Jura x7 coffee machines are older models in the coffee machine range. It may simply require a full system clean, using jura cleaning tablets, or more likely a service. Bean to cup machines should really be serviced every year to 18 months depending on usage.
We can put you in touch with a Jura engineer if you need one, contact me here Denby Dale Coffee
Jura Capresso... | Answered on Mar 23, 2015
check small float in tank is not stuck in the down position
Jura Capresso... | Answered on Jan 30, 2015
Short answer: You need to lubricate the plunger mechanisms in the brew unit.
Long answer: There are two rubber o-rings - one in the base of the brew unit and on the plunger that descends into this to form a seal. There are great instructions on how to take apart, clean and lubricate the brew unit here:
http://www.buessert.de/Technik/Jura-IMPRESSA-S95/Cleaning.htm
...but they are not for the faint hearted.
There is also a cheats way too which I use.
First, get some SILICONE lubricant. It needs to be Silicone. You can get it from ACE for $3.
Remove the door / funnel mechanism from the powder inlet - it just lifts out.
Usign a flashlight, take a look inside where the coffee grind goes. You will see a cylinder with a plunger mechanism at the bottom. You need to lubricate the ring on the bottom plunger and the tope one (which you cant see this way).
Use the flashlight and a knitting needle and place some silicone at the base of the plunger - you will see what I mean when you look inside with the flashlight. Also put some around the top lip of the cylinder (for the upper plunger). It is sticky and messy.
Press the "rinse" button.
You can do this a few times. The silicone will not affect the taste of your coffee. I tend to put a liberal amount in and then wipe off the excess with a kitchen towel on the end of the knitting needle.
This is fiddly, but it works. I do this in between complete disassembly, which I do about once per year using the above instructions. If you need to replace the o-rings, you should be able to find suitable replacements at a local hardware store but this is a trial-and-error process, I'm afraid. I have never ordered the ones linked to on that page.
Hope this helps.
Now, if only I could work out how to fix the leak from the rear....
Rgds, John
Jura Capresso... | Answered on Mar 11, 2014
I have the same problem..... you have a faulty brew unit... you will need to send your unit to Jura USA for repair..... I know this the hard way as I cant get them to sell me the darned spare part....
Jura Capresso... | Answered on Mar 25, 2013
Hello.
1 Perform the initial setup on the coffee maker. Make sure the coffee maker is not plugged in. Slide the empty funnel into the funnel guides, fill the decanter with cold water, open the lid and pour water from the decanter into the brewer, put the decanter back on the base, then close the lid and wait three minutes for the internal tank to partially fill. Open the lid, fill the decanter with cold water again, and once more pour the water directly into the brewer. Put the decanter back on the base and wait for water to flow out of the funnel and into the decanter. Once it has stopped flowing, pour out any water that is in the decanted and plug in the coffee maker. Press the on switch to turn the coffee maker on and heat up the water in the tank.
2 Ensure the lid is completely closed. If the lid is open, the Bunn coffee maker will not brew coffee.
3 Check the see how much water is in the water tank. The Bunn coffee maker will not begin brewing coffee if less than 20 ounces (4 cups) of water is present in the water reservoir tank.
4 Delime the coffee maker. Unplug the coffee brewer and allow it to cool down. Remove the sprayhead by turning it by hand and set it aside. Insert the flexible deliming tool into the sprayhead tube until all but two inches are showing. You may need to twist and force the tool to go in. Slide the tool in and out several times to loosen lime buildup.
Check the sprayhead for lime buildup. If there are flakes of minerals, they can be removed with a toothpick. Scrub the sprayhead with soap and water. Rinse the sprayhead with water and replace it in the coffee maker. Pour water into the water tank and turn the coffee maker on, allowing water to run through without making any coffee. This will flush any lime fragments through the system. Empty the decanter
Thanks.
Jura Capresso... | Answered on Sep 18, 2011
Then it is a problem with the flowmeter. This needs to be changed, please contact your local dealer.
Jura Capresso... | Answered on May 13, 2011
According to your problem, decaling is necessary for after every 300 cup coffee. Check the water knob and water passing pipe if there is any blockage. Open the machine by unscrew it and check the circuit or you can take assistance from nearest engineer because it is not too easy job for a nontechnical person. You can also try by help of manual. To get the manual you can visit wbsite or nearest dealer of the product.
Jura Capresso... | Answered on May 07, 2011
Did you work it out? I am having the same problem with my X&-S model.
Jura Capresso... | Answered on Jan 03, 2011
if you put the tea on the tv the tv is brokan
Jura Capresso... | Answered on Dec 11, 2010
Jura Capresso Impressa S90 Espresso Machine Logo
49 questions posted
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Impressa Jura Capresso
  • Impressa Jura Capresso
Most Popular Question
error message 8
  • Coffee Makers & Espresso Machines
