SOURCE: PANASONIC KXTG5432M PHONE
No, you cannot add a set to this phone. But if you are going to up grade then buy one that says expandable. KXTG5433M has only 3. Some Expandaables can have up to 10 or 12.
SOURCE: BT Studio 3500, Base station,
eventually contacted the BT team via telephone and apparently this is a common problem when using BT products with Talktalk & Virgin. To overcome this in the majority of cases, dial 1571 and connect to your voicemail, listen to the options and finally delete all messages. Hope this can be added to your list of solutions.
SOURCE: Unable to talk on two handsets at same time when receiving a call
Unfortunately that is the untold story about cordless phones they only have the capability of 1 open line be it the handset or or the base. There are some very pricey multi line systems, I have the same system bought two extra handsets and found out too late that I can only use them one at a time! Sorry probably not the answer you were looking for but thats the reality...
SOURCE: Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Testimonial: "This responder did nothing but repeat my initial post and yet gets credit for a solution?"
